Fourier Analysis for NVH - Reference info to understand the Fourier Analysis method
L
Lugon
Hello, looking for reference information to understand the Fourier analisys method to measure surface finish to evaluate potential Noise, vibration, and harshness (NVH) risks. Need to go back and set up a grinder machine but we are not sure what parameter(s) we should change based on the measurement result.
Muchas gracias!
H
Hodgepodge
Re: Fourier Analysis for NVH - Reference info to understand the Fourier Analysis meth
I've never heard of anyone applying this specific label to troubleshooting surface finish issues but you can call it whatever you like. I’m also not sure how to evaluate “potential Noise, vibration, and harshness (NVH) risks” on a grinding machine set up. Vibration would be a key item but any vibration in the machine should stand out like a sore thumb.
The parameters involved are:
Workpiece material
Workpiece hardness
Workpiece Weight
Workpiece diameter (or length)
Workpiece stock amount on final passes
Workpiece Location and rigidity
Workpiece RPM and/or Traverse Speed
Wheel type
Wheel hardness
Wheel grit
Wheel Ø
Wheel Speed
Wheel Surface Feet/Minute
Dressing Diamond Type and general condition
Traverse Speed of Dressing
Coolant application
Coolant Type
Coolant Viscosity
Coolant Cleanliness
When grinding, there are so many different combinations of factors that come in to play. The biggest contributing factors are those in bold.
Can you be more specific with your problem?
Ronen E
Problem Solver
Moderator
Muchas gracias!
Hello and welcome to the cove :bigwave:
You can read about it here:
http://en.wikipedia.org/wiki/Noise,_vibration,_and_harshness
Follow the link under "Investigative techniques" for some discussion of Fourier transforms. AFA I understand it is based on analysing a time series, but I guess that in the context of surface finish you could do the same if you replace time with location along a measured surface. just a wild guess :notme:
Cheers,
Ronen.
L
Lugon
Thanks to all who have replied.
I apologize if I was not clear on my inquiry for information.
This is in fact a blue print call out, this is how is stated:
SHORT WAVINESS INTERPRETED USING FOURIER-ANALYSIS.
EVALUATION 5. TO 300. ORDER
n0 = 0.7
K = 0.6
R = 3
We are dealing with out of spec parts, our shafts have up to 4 journals and the out of spec condition jumps from one to another as we play with RPMs, feeds, dwells and other parameters.
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
O Quality Management System Implementation framework and Gap analysis checklist Manufacturing and Related Processes 7
S Consolidated Analysis Report for Moulding Process Manufacturing and Related Processes 1
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
T ANOVA analysis to find F test. Using Minitab Software 3
N Failure Analysis-Potting Gel and Sealants Manufacturing and Related Processes 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B How to exclude empty rows in full factorial design analysis? Using Minitab Software 0
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 9
Q Process map Evaluation and Analysis Method Process Maps, Process Mapping and Turtle Diagrams 5
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Recurrent event analysis software (python) General Auditing Discussions 2
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M MDSAP and 13485:2016 gap analysis Quality Management System (QMS) Manuals 1
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
M 10993-11 vs 2006 gap analysis Other Medical Device Related Standards 2
