Frequency of Gage R&R and Measurement Uncertainty
Tammy N
I have a question about uncertainty measurement and Gauge R&R. Once they both have been performed and recorded, how often must they be repeated in accordance with ISO 17025?:D
BradM
Re: Frequenty of R&R/ Measurement Uncertainty
As far as R&R, I would perform it often enough to determine if the process is stable. Do you hire new people? Do variables change in the process? Do you make improvements and such to possibly lower the variance? Or, did it go up?:D
As far as calculating the uncertainty, I would recalculate whenever any of the variables involved with the estimation change. If you receive a new reported uncertainty for the standard, R&R varies, different environmental conditions, etc.
Obviously, I would perform analysis much more frequently at the beginning of the process. The frequency (and possibly number of replications) can reduce once you can demonstrate consistency/ stability.
So, start off often and frequent, and review the data. Once you have established consistency, then consider extending the intervals. For uncertainty, recalculate when there is good reason to conclude a variable has changed.
:2cents:
Rebecca Bowes - 2010
I would suggest that whoever is planned to use the gage successfully go through the gage R&R study. I would also plan to do a new Gage R&R annually. Just my opinion.:cool:
Tammy N
Thank you for the input. I started with this company 3 months ago and the uncertainties have not been looked at in over 2 years.
I have an ISO 17025 audit at the end of this month and I wanted to see if I have to explain the gap.:)
BradM
Well, I would certainly not stress out too much over it. After all, you are inheriting the system. I would let your management know the status of the program, and any possible concerns that you may have.
If it was me, I would do as you suggest and perform a gap analysis. Also, I would focus on your processes from a risk-based perspective. Try to take care of the important things first; then go from there.
Hershal
Metrologist-Auditor
Brad is right about redoing MU when things change.....for example, if your standards go out for calibration, when they get back recalculate your uncertainty.....
Remember uncertainty changes constantly, but the difference is the resolution needed to see the constant change.....
Tammy N
I am in the process of updating all of the uncertainties. Thank you for all of your input, it is greatly appreciated.:thanx:
cfilion
All, We need both?
Our lab is ISO 17025 and we have just finished a very long GRR study of all of our scope of accreditation tests. We have to perform the MU on these various tests. Can't I just use the GRR to evaluate the MU? It would probably be a larger number than a real MU but it would be safe.
For example: (our worst test)
Gage R&R Study - ANOVA Method
Two-Way ANOVA Table With Interaction
Source DF SS MS F P
Lot 1 4980.63 4980.63 109.283 0.009
Techniciens 2 48.70 24.35 0.534 0.652
Lot * Techniciens 2 91.15 45.58 21.862 0.000
Repeatability 84 175.12 2.08
Total 89 5295.60
Alpha to remove interaction term = 0.25
Gage R&R
%Contribution
Source VarComp (of VarComp)
Total Gage R&R 4.984 4.35
Repeatability 2.085 1.82
Reproducibility 2.899 2.53
Techniciens 0.000 0.00
Techniciens*Lot 2.899 2.53
Part-To-Part 109.668 95.65
Total Variation 114.652 100.00
Study Var %Study Var
Source StdDev (SD) (6 * SD) (%SV)
Total Gage R&R 2.2325 13.3951 20.85
Repeatability 1.4439 8.6631 13.48
Reproducibility 1.7028 10.2166 15.90
Techniciens 0.0000 0.0000 0.00
Techniciens*Lot 1.7028 10.2166 15.90
Part-To-Part 10.4722 62.8335 97.80
Total Variation 10.7076 64.2454 100.00
Number of Distinct Categories = 6
Gage R&R for Melt flow ASTM D1238
So this test can distinguish 6 distinctive products from a total process variation of 64.2454 (6 sigma). So any difference under 10.71 (64.2454 / 6 .. # of categories) is not significant! So my tool's measurement Uncertainty should be (in the range measured) ± 5.35 (10.71 / 2 .. since 10.71 is my full range) .
So am I Ok or I should go back to school?
bobdoering
Stop X-bar/R Madness!!
Gage R& R really has no time function - if it is performed correctly at the beginning - which means the parts and the operators cover the variety of possible levels the gage will see over time. If later you get operators less capable than your original operators, then that is significant enough to redo the gage R&R again. Some folks like to R&R every new operator. Again, that is academic (unless their gaging system has been shown to be so operator dependent that it should not likely be used anyway.)
If the gage is changed, or the measurement process changed, then yes, it needs verified. Improvements can fix one thing, and break another. But, lacking any significant changes to the measurement system, redoing them at any frequency is, again, simply an academic exercise.
As far as stability, my preference is to use calibration data - if the same standards and enough measurement points to establish linearity are used -to establish stability over time. That way I can see measurement change not tainted by any measurement error (such as influenced by roundness, etc.)
This is true unless the measurement device becomes damaged or enters the wear out phase of it's life cycle.
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
D TS 16949 Gage R&R Frequency Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
A Determining Gage R&R Frequency Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Gage R&R Frequency required by TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 33
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
K Gage R&R Frequency - How often to perform the GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
W Gage R&R study frequency - How often should a Gage R&R be performed? Capability, Accuracy and Stability - Processes, Machines, etc. 8
R Gage R&R Frequency - Are your GR&R's on a set schedule? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
R EXTECH Oyster-10 Calibration Frequency (pH/mV/Temp gage) Calibration Frequency (Interval) 2
T TS 16949 Requirements: Frequency of Gage R&R Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E What are the requirements, including frequency, of Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Bioburden Frequency (sterile MD) Other Medical Device Related Standards 2
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
L Calibration Frequency for Surftest SJ-400 General Measurement Device and Calibration Topics 0
G ISO 9001 - 9.3.1 Management Review - Content and Frequency Management Review Meetings and related Processes 12
H Frequency of shelf life/sterilization/bench studies conducted on a medical device Other Medical Device Related Standards 1
M RFID (Radio Frequency Identification) Registration in Europe and in MENA countries EU Medical Device Regulations 1
M Leakage current measurement with non-frequency-weighted device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Requirements for Interval Measurement test & Frequency Response test clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B Radiation Sterilization Dose Audit: Bioburden frequency Other Medical Device Related Standards 1
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
D IATF 16949 surveillance audit frequency IATF 16949 - Automotive Quality Systems Standard 16
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
R Internal Audit Frequency - Remote Site (a Design Center) IATF 16949 - Automotive Quality Systems Standard 3
V Periodic Audit Trail Review - Scope, Content & Frequency Qualification and Validation (including 21 CFR Part 11) 10
JoCam Required Frequency of Notified Body reviews of Technical Files EU Medical Device Regulations 6
Q AMS 2750E System Accuracy Test (SAT) Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B MHRA Unannounced Audits Frequency Changed? EU Medical Device Regulations 2
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q RFID (radio frequency identification) registration for Medical Device Other Medical Device Regulations World-Wide 6
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
N Tool frequency change - Data Analysis needed Statistical Analysis Tools, Techniques and SPC 9
GStough Adequately Defining Which Suppliers to Audit and Frequency Supplier Quality Assurance and other Supplier Issues 8
Y FDA's Inspection Frequency for Foreign Manufacturer Other US Medical Device Regulations 1
R TS 16949 Process Re-Validation Frequency Requirements IATF 16949 - Automotive Quality Systems Standard 3
