From paper to Electronic (records) in the QMS
qualprod
Hi everybody
I´m in the phase to migrate a QMS from paper based records to an ERP system,, all the procedures, forms,etc., are maintained in
PDF formats.
For the release of products, authorization of work orders, etc., we printout forms and on papers the approvals are handwritten signatures, then
such documents are scanned out and saved in the network.
The idea is that all records that currently are stored in scanned PDF be managed into the ERP with just applying approvals commands, with
check marks into the ERP.
When someone need to check an approval of something, just enters in a log file (text or graphic file) where
will appear name of operator, date , time and the activity.
All the requirements for records according to 7.5 are considered, (time retention, backup, etc.)
Question for all of you.
Will I face a problem, objection of an ISO, IAF , CB or some other standard for having all records in electronic
way? or are there some guidelines to do this?
Thanks in advance
John Broomfield
There’s a standard for that:
ISO 14641:2018
Provide the necessary training and equipment to continue making, filing, archiving and using the required records.
Check the indexing, retrievability and legibility of scans of hardcopy records.
The main long-term risk may be maintaining the ability to retrieve records given changes in combinations of hardware and software.
Of course, you’ll be completing your own risk assessment.
Please let us know how it goes.
qualprod
ISO 14641:2018
Thanks, John
Maybe I was misunderstood.
My idea is to change the current approach, which is not to use signed papers anymore.
Current approach:
Now we use papers with signatures, then scanned out such records (evidences) and stored somewhere.
If need the evidence of something, just open the pdf file and see who did such approval, time,date, action, etc.
Future approach:
To enter into the ERP system, and apply approvals on screens (mouse clicks on boxes)
such actions will save such evidences in log files.
If need to have the evidence of such approvals, open into the ERP system such log file
and can be seen who did an action, date, time, etc.
I think at this level is enough in order to comply with the ISO standard which does not require signatures.
Although I could try to add the option to write with an electronic pen the signature into the application.
But I´m entering in other zone.......
When is it needed the electronic signature?.....
Please share your thoughts
John Broomfield
Sorry about that.
Three questions illustrate my concerns:
1. So, every user of the ERP system has their own log-in?
2. And the login credentials include each user's approval authorities?
3. And how long before the ERP system logs off a user for inactivity?
You may have more.
Bottom line, could unauthorized users change the status of draft, approved or superseded docs and what would be the consequences?
Tagin
Requirements for signatures would come from customers, or perhaps regulatory/statutory requirements. As you say, ISO 9001 does not require signatures.
We scan in filled-out forms and save them as PDFs in the ERP system, and we use ERP log files as records of approvals within the ERP system; we've never had a problem with an ISO auditor.
qualprod
Sorry about that.
My question in italic blue
Yes, and each user has its own profile, according the authorities and responsibilities
YES
After 15 minutes of inactivity, the system logs off the user.
You may have more.
No, because only authorized users can change status of documents.
Although this is not my case, because now I´m focused in my ERP system, and what you mention would apply to change procedures
of a QMS, which is planned to be migrated in short to a software App.
In here, I have to take care of this issue.
Clearing up, my original question, is the way to change my paper signed ISO records to be included in my ERP.
Now my QMS is still manual/electronic, we manage all the QMS in electronic format (say in PDF in the network)
but the management is still manual.
Hope is clear
qualprod
Thanks Tagin
2 comments.
1- Why the filled-out forms, are not filled-out into the ERP system?, imagine the form in the screen and just using the mouse or maybe a barcode scanner to input data in the electronic form fields? because I suppose currently you fill out forms by hand.
2- In order to keep evidences of actions, log files are very usual.
Regards
Tagin
Thanks Tagin
2 comments.
Regards
Forms: 1) customer requirements for handwritten signatures on some of those forms, 2) creating a form in our ERP is not possible, 3) not all locations have a device that would be easy to fill out forms electronically.
qualprod
Thanks Tagin
One more last opinion.
In your point of view or other cove members.
In what do you trust more?
1 A log file, simple text, how to be sure that person mentioned in the file, is really who approved the document?
2 In a signed paper by hand, how to be sure that person name who signed the form, really is the mentioned.
It is clear that for these cases the two ways are enough for some purposes (ISO systems or customer requirement)
When that is not enough, well, we have to go with fingerprints face reader,etc.
Are you agree?
What do you have to say about the two options?
N Converting Paper Records to Electronic Format Records Document Control Systems, Procedures, Forms and Templates 6
V 21 CFR Part 11 Electronic Data Storage Requirements vs. Paper Records Qualification and Validation (including 21 CFR Part 11) 2
D Transferring Paper Records to Electronic Record Archival Records and Data - Quality, Legal and Other Evidence 4
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 6
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
P Moving from a Paper based Quality System to an Electronic Quality System Manufacturing and Related Processes 14
S Migrating from paper based to electronic system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
S 21 CFR 11 - Require paper and hand signatures not electronic Other US Medical Device Regulations 2
I Electronic vs. Paper Copy Document Approval Process Document Control Systems, Procedures, Forms and Templates 9
Q Red Stamped Printed Paper vs. Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
S Best way to control blueprints? Electronic or paper? Document Control Systems, Procedures, Forms and Templates 1
A The cost of document control - Electronic vs. Paper Document Control Systems, Procedures, Forms and Templates 20
Mustapha Paper Record Scanning and Discarding ISO 13485:2016 - Medical Device Quality Management Systems 5
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Regulations on Controlled Document Size (Paper Size) Document Control Systems, Procedures, Forms and Templates 4
dgrainger Informational EC - Medical devices – online manuals replacing paper instructions - Feedback period: 27 April 2021 - 25 May 2021 EU Medical Device Regulations 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 19
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
B Do you use paper or web-based templates for CAPA processes? ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 45001 Lead Auditor Exam paper Training - Internal, External, Online and Distance Learning 1
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US – MITA UPDATES SERVICING AND REMANUFACTURING WHITE PAPER Medical Device and FDA Regulations and Standards News 0
M Informational FDA discussion paper – Consideration of Benefit-Risk Approaches for Weight-Loss Devices Medical Device and FDA Regulations and Standards News 0
M Informational Paper on open access – EU postmarket surveillance plans for medical devices Medical Device and FDA Regulations and Standards News 1
L Dying a slow SCOPE death - NEW ISO APG Paper on Scope and Applicability May 2020. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Sidney Vianna Interesting Discussion ISO 9001 audits from the perspective of registrants' customers - an interesting paper Registrars and Notified Bodies 0
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
M Informational COCIR Position Paper Harmonisation of Standards for Medical Devices Medical Device and FDA Regulations and Standards News 0
M Informational COCIR paper – Advancing Cybersecurity Of Health And Digital Technologies Medical Device and FDA Regulations and Standards News 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
C Karl Fischer Titrators and 21 CTR Part 11 and Paper Records Qualification and Validation (including 21 CFR Part 11) 6
M Medical Device News NB-Med and Team-NB have jointly edited a white paper entitled “White Paper – One Year of Application” Medical Device and FDA Regulations and Standards News 0
S Paper-based QMS ISO 13485:2016 - Medical Device Quality Management Systems 9
M Position paper Team NB Statement - Patient safety EU Medical Device Regulations 0
G Calibration Certificate, fancy paper or not? General Measurement Device and Calibration Topics 9
T ISO 9001:2015 by Craig Cochran - ebook or paper? Coffee Break and Water Cooler Discussions 9
M Design of Experiments - Paper Helicopter Example Using Minitab Software 1
A Splitting Paper Routing Job Worksheets AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
L BSI White Paper on Human Factors/Usability Engineering IEC 62366 - Medical Device Usability Engineering 12
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
A Receiving paper from the customer and never knowing when it will arrive Quality Manager and Management Related Issues 1
G Paper Based Manufacturing with an Unvalidated ERP ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Kraft Paper / Core Paper MSDS - Plastic Specs IATF 16949 - Automotive Quality Systems Standard 4
