Fulfilling ISO 9001 Document Review Requirements
Tarrah
Good Morning All!
It has been a while since my last post, but you are all so helpful I would like to solicited some advice from you relating to the review of procedure requirements.
We currently have our review scheduled for every 2 years, however, this requirement is not currently being managed. It is hard to provide evidence that the procedure had or had not been reviewed. Do you have any examples of a system that worked well to provide this objective evidence and helped to maintain compliance to the requirement?
Tarrah
qusys
Re: Fulfilling Document Reviewing Requirements
Good Morning All!
Tarrah
Hi Tarrah,
you could proceed in many ways.
For instance, manage the expiring due date of the document manually, creating a list with all the document and the date of issue, then you can set on Outlook calendar the next review date as per your document procedure ( 2 years), if in the meantime no revision occurred. You can notify the process owner or the owner of the document at least three months before the expiring date.
On the hand , you can buy an electronic document mgmt system that does this job automatically , based upin the features you set.
Hope this helps:bigwave:
RoxaneB
Re: Fulfilling ISO 9001 Document Reviewing Requirements
Tarrah:
There are several ways to accomplish the activity of document review and they vary from simple to complex and from automatic to manual. It is up to your organization to determine which option will add the most value.
1. Outlook calendar is good - but what if people leave?
2. Excel log of all documents, including next review date. Coordinator contacts document owner for review to be done. Email of review being done is maintained (i.e., record).
3. Electronic software.
Another aspect to consider is the spread of the review dates. If a document owner is responsible for 20 documents and they all come due for review within two weeks, that's a lot of reviewing to do, plus a person's normal job. Considering spreading them out over the course of review period, where possible.
K
Ka Pilo
Good Morning All!
Tarrah
It is a good idea to read through every document more frequently and say to yourself "Is this still relevant?" or "Does this match actual practice?" etc
You can include an "Ownership" section of each document stating something like "The Job Title is responsible for ensuring that this document is necessary and that it reflects actual practice."
As for the evidence of review, maintain a record of review even if the contents haven't changed to confirm suitability. Or you may want to add a review date and reviewed by column to this to prove a document has been reviewed.
RoxaneB
While the idea of a more frequent review is practical - depending on the number of documents that Tarrah's organization has established - reading through a document does not provide the objective evidence of the review being done.
Can you provide suggestions on how she should maintain a record of the review. I think this is what is being asked by Tarrah.
K
Ka Pilo
Thanks for the advice. I have edited my post and added my suggestion for "evidence of review" query.
I'm wondering if issue number and issue date will suffice without the "reviewed by" bit on it. What do you think?
Colin
Isn't part of the role of internal audit to review the procedure? In particular 8.2.2 b) where it requires the organisation to determine whether the QMS is effectively implemented and maintained.
The audit records then become the evidence that the review took place and any subsequent actions required following the review.
RoxaneB
An audit (be it internal or external) can not review every possible document within an organization. An audit performs a "review" on a sample number of documents.
Is it not part of the standard that each document be reviewed for its adequacy? This ensures that internal personnel can ensure that the documented process properly aligns with the actual process.
Pancho
wikineer
Good Morning All!
Tarrah
Hi Tarrah,
The requirement in the standard (§4.2.3.b) is for you to "define the controls needed to review and update ... documents". The standard does not mandate a review nor evidence of it. The difference is subtle but important.
You have defined a control to be "review each procedure every two years". Fine. Lucky you to have very stable processes. Why not simply add that "if upon review it is found that no update to the procedure is required, then no further action is necessary. If an update is required, then the procedure is updated in accordance with [SOP: Procedure updates]"?
That would still meet the §4.2.3.b requirement, and save you unnecessary paperwork.
(As a side note, every time someone, anyone, consults a procedure they are also reviewing it. If they find a discrepancy between the procedure and the way they must do the work, they should fix the procedure, if they can, or raise a CAR. If you code this into your QMS, your docs and processes will improve very fast.)
Good luck!
Pancho
Colin
Roxane, I was think more in terms of reviewing the procedures rather than all documents. I agree that the internal audits will only take a sample of documents but I suspect that most procedures will be reviewed as part of the internal audit programme. As Pancho points out, the clause states 'review and update as necessary'.
Sidney Vianna Is the ISO TC176 fulfilling its Vision & Mission? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
A Fulfilling the requirements of AS9120A Clause 8.2.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Fulfilling Training Requirements - We have NO Training Records on anything ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Marc Definition Pygmalion Effect - The Self-fulfilling Prophecy Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 3
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
