Function for Effects - Beginner in usage of the IQRM
aantal
Please help,
I am beginner in usage of the IQRM and i am facing the folowing problem
I have created standard for several processes and i want to build up a process from this standard ,but during copy it makes several link betwen the standard see the attached file.
How can i eliminate this kind of connections from the file without deleting several process effects data "See Function for effects in the function area"
View attachment IQRM.xls
aantal
IQRM.xls
jeilers
The problem is that the anchoring point for effects with the name “Function for Effects” is anchored at the process element “Camera check”. I can only guess that you have created a structure with a FMEA form for the root element.
If you are familiar with the structure editor you can do the following:
- select the old root element
- Menu: edit - new - new root
- Drag & Drop “Function for effects” to the new root
If my assumption is wrong and there is already a root element without the FMEA form you can directly move the “Function for effects” to this root element.
If you are only familiar with the FMEA form editor you can do the following:
- select process element and hit the Ins (= insert key)
- input a new element “Camera check”
- Drag & Drop all functions - exept the "Function for effects" - to the new “Camera check”
- select the first process element which will now show only “Function for effects” and hit the Del (= delete key).
Hope it works.
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
K Multiple function device products EU Medical Device Regulations 0
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
J Auditing of Support Function IATF 16949 - Automotive Quality Systems Standard 9
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
T Spirometer - Pulmonary Function Testing - ATS/ERS:2005 EU Medical Device Regulations 5
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Function definition for DFMEA FMEA and Control Plans 1
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
S Status products when/if the QMS ceases to function? EU Medical Device Regulations 1
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
W Is sharing resources treated same way as remote function? IATF 16949 - Automotive Quality Systems Standard 1
H Conveying Form Fit and Function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G Function in french called "numbre de posage(s)" - CMK Question Quality Tools, Improvement and Analysis 3
M Remote Office only has Invoice Function - Audit Needed? IATF 16949 - Automotive Quality Systems Standard 0
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
F Which Business Function should Approve Suppliers and maintain the ASL Supplier Quality Assurance and other Supplier Issues 8
L How to Introduce the Quality Function to the production floor in a bad environment Misc. Quality Assurance and Business Systems Related Topics 6
A ISO 27001 function wise or department wise audit questionnaire with control & clauses IEC 27001 - Information Security Management Systems (ISMS) 3
M Taguchi Loss Function Problem Misc. Quality Assurance and Business Systems Related Topics 2
C IVDD 98/79/EC Measuring Function Requirements EU Medical Device Regulations 2
N Regulatory and Safety Standards for Medical Device with Measuring Function IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
L Remote Control Inspection Digital Indicator with a TIR (range) function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J CE Mark Classification for a a pulmonary function test filter CE Marking (Conformité Européene) / CB Scheme 2
S Outsourcing PPAP Function APQP and PPAP 8
F What is an FAA PAI Maintenance Function List? Federal Aviation Administration (FAA) Standards and Requirements 3
Z Scope of Employee and Function Levels of Internal Audits Internal Auditing 3
T Difference between the terms Function & Process when used in Construction Management Business Continuity & Resiliency Planning (BCRP) 12
N Role of Quality Function in Approving Work Instructions Document Control Systems, Procedures, Forms and Templates 4
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
V Annual Performance Appraisal - Person vs. Function/Business Career and Occupation Discussions 5
B Which type of DOE was likely used for this transfer function? Six Sigma 4
P Nonlinear Fit for a Complicated Curve - Fitting a Function to the Data Statistical Analysis Tools, Techniques and SPC 6
V SOPs and Internal Audit Criteria for Regulatory Affairs (Submissions Function) US Food and Drug Administration (FDA) 4
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
S Probability Density Function of a Function of a Random Variable Statistical Analysis Tools, Techniques and SPC 13
J Definition Form Fit or Function - Materials Composition and Manufacturing Processes? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J Function of a Change Number in our ECN / document vault program as a tie-in Problem Solving, Root Cause Fault and Failure Analysis 3
M Quality System Procedure for HR Function needed Document Control Systems, Procedures, Forms and Templates 4
S Critical to manufacturing but not product function - Non-conformance or Not? Nonconformance and Corrective Action 12
M TS 16949 and Form, Fit or Function? What about Calibration of Oven Controllers? IATF 16949 - Automotive Quality Systems Standard 5
M Devices with Measuring Function - Do rulers and calipers count? EU Medical Device Regulations 7
