Future of APQP and PPAP in Doubt? 2005 Update
Marc
I was doing some searching and saw this:
http://www.qualitymag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,6425,99169,00.html
Posted on: 05/05/2003
By Roderick A. Munro
As ISO/TS 16949 moves toward becoming the newest standard in the automotive arena, Advanced Product Quality Planning (APQP) and Production Parts Approval Process (PPAP) and their applications--which were born out of U.S. initiatives--will undoubtedly reflect the changes brought by the new international standard. The impact of ISO/TS 16949 on the U.S. automotive industry will be felt all the way from the supply chain to the automotive assembly lines.
The article looks dated despite the posting date of 5 May 2003. And the content does not appear to support the article title per se.
Any comments?
Bigfoot
Marc,
I have heard some noise, but can't remeber where I heard it, that the APQP manual was on it's last leg and would not be revised again due to the detailed manner with which Product Realization is spelled out in section 7 of TS-2. I have not heard anything regarding a departure from supporting PPAP. :eek: Although each of the BIG 3 have their own quirks now it is still better than the confusing :mad: mess it was when each of them had their own process instead of a common format for the Product Appproval Process.
Howard Atkins
Forum Administrator
I think this is just a very formalistic look at the requirements.
"A rose by any other name is still a rose"
QS9000 called out the AIAG manuals, TS calls out customer demands.
The VDA (German) has a defined method of ISIR - PPAP which is very similar .
The French have a similar method etc.....
With the growth of globalisation Eurpean and US companies are gradually consolidating their demands.
I do not know much about Japan but I am sure that someone will add this aspect.
If in the past there was one reference book, for those that worked only in or with the US there are now international sources.
If you work only in or with the US there should be no difference to you.
D.Scott
I agree with Howard.
The big trouble as I see it is that we seem to be going back to the old days Bigfoot referred to. It seems now we are again faced with 5 or 6 different versions of the same requirement, each carrying specific forms and paperwork.
The thing that makes it real scarry is the further down the supply chain you go, the more "customer specific" requirements (read interpretations) are imposed.
Dave
Tom W
Interesting points, but do we see the US based AIAG books going away? Do we really think the big three can agree to something like that? Sounds like a typical big 3 situation that make more work for suppliers and less work for them. They pick and choose what they themselves will follow; yet demand a lot more from their suppliers. Strange thing is their suppliers are actually their customers????
bpritts
Involved - Posts
A few days ago, I saw a reference that stated that the GM-Ford-DC task
force was reviewing and revising PPAP right now. Can't remember where
I saw it - maybe it will come back to me. Probably an AIAG newsletter.
Also, I have been told that Ford has had its own FMEA standards for some
time (don't supply them, so I haven't had the need to learn more.)
SImilarly, Delphi has its own "takes" on items such as P-FMEA (they have
unique rating #'s for frequency, severity, and detection; a proprietary process
flow diagram approach, a proprietary run-at rate approach... ). To their
credit their stuff is pretty well done, but the advantage of a standard is...
that it's standard!
GM has its "Quality System Basics" program which gives a number of
prescriptive methods for handling customer complaints, doing "layered"
internal audits; defining the format for work instructions, etc.
I share the concern that we're moving back to the company specific world.
Brad
Dave
I have similar concerns. QS started because we had a zilliion different requirements from the Big 3. They wanted to standardize the way things were done. I was hoping the consolidation would continue (for example having one corrective action process) Now, it appears we are swinging back the other way.
Oh well, it helps keep us consultants working. :rolleyes:
Rob Nix
When the bully on the block feels he's losing his grip, he gets a better grip with the other hand. When the big-3 were truly BIG, the only game on the block, they had CONTROL. The AIAG did their bidding. And consolidation of standards was a good thing. After all, PPAP is based on GM's original GM-1386 form and GR&Rs still follow GM's long method - and Ford promoted SPC and Cpk studies before the merging began.
HOWEVER, with globalization came the loosening grip of the big 3. It appears the AIAG / IASG is weakening under the broader IAOB / IATF. I imagine the big 3 are trying to restore things to as close to the vest as possible. And their off shoots, e.g. Delphi, Visteon, etc. are now execising their independence and doing the same.
So I agree also. I think we are seeing things going in the other direction, perhaps even seeing special 'customer specific' quality system audits return. :frust:
I
isogirl - 2004
Perhaps this should be titled the "Evolution and De-Evolution of the Automotive QMS". Here is an update on revisions from AIAG's Quality Quickbytes.
SteelWoman
Does indeed seem odd. Our auditor recently told us to get OUT of the habit of using the phrase "PPAP" - we must use Product Approval process now, supposedly to steer us toward what the "customer" wants and away from old QS thinking. I just finished up my plant-wide "Introduction to TS16949" training, and it took all I had to tell the groups that TS was supposed to be (emphasis on "supposed") a more cohesive, unified system than QS. I agree it seems to be devolving into the exact OPPOSITE. We can't do PPAPs anymore - we have to do the Product approval process agreed upon by the customer? Which could, in theory, be any of a zillion different methods?
I just queried all my customers to find out whether they want us to use the AIAG PPAP manual as their preferred method, or if they prefer another method. Without exception, they all chose the AIAG PPAP manual.
I'll just go take my AIAG manual and cross off the title and write in PRODUCT APROVAL PROCESS - that should make the auditor happy, right? !
D What foreign language proficiency would give the biggest edge to medical device regulatory affairs professionals in the world today or in future? Career and Occupation Discussions 6
Ronen E Informational The future of MEDDEV 2.7/1 EU Medical Device Regulations 4
M Informational Technology and innovation of human implants | Panel for the Future of Science and Technology (STOA) | European Parliament Medical Device and FDA Regulations and Standards News 0
Sidney Vianna IAQG News Future AS9147- Management of Unsalvageable Parts - Previous scrap parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Reviewing a supplier's ISO 9001 certificate issued for a future date Registrars and Notified Bodies 10
Sidney Vianna The Future of Spaceship Earth - The UN Sustainable Development Goals Sustainability, Green Initiatives and Ecology 1
Marc The Future of Geothermal Energy Coffee Break and Water Cooler Discussions 0
M The future of ISO 14971:2007 ISO 14971 - Medical Device Risk Management 2
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
J Potential Customers Asking for EIRs / 483s when evaluating a CRO for future work US Food and Drug Administration (FDA) 2
A Future as an AS9100/NADCAP Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Any future for someone working as Lead Quality right these days? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Marc Annex SL - Format for Future ISO Management System Standards Other ISO and International Standards and European Regulations 7
8 New Job Presentation on my findings and plans for future Lean in Manufacturing and Service Industries 6
D What's the future of supplier quality engineer for your worklife? Supplier Quality Assurance and other Supplier Issues 3
Marc The future of 3-D Printing Manufacturing and Related Processes 18
S What is the future of ISO 50001 EnMS (Energy Management Systems)? Miscellaneous Environmental Standards and EMS Related Discussions 3
somashekar BAA (Buy American Act) and the future of Asian Economy Business Continuity & Resiliency Planning (BCRP) 15
G The future of the Process Approach to Auditing General Auditing Discussions 10
Marc Predicting the Future through 19th Century French Post Cards Coffee Break and Water Cooler Discussions 1
P Contract up in 1.5 months - How to approach my manager to discuss the future Career and Occupation Discussions 15
M Future revision of ANVISA RDC 59 - Brazilian GMP Other Medical Device Regulations World-Wide 14
automoto How ISO 9001 could look in the future - ISO 9001 revision (Guide 83) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
AnaMariaVR2 Emergence ? 2011 Future of Quality Study [ASQ] The Reading Room 4
P Future Materials Storage Issue: Is this a finding? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
8 Introducing a Balance Line - Identifying potential future pitfalls etc. Lean in Manufacturing and Service Industries 2
AnaMariaVR2 QbD, PAT, and the Future of Microbiology Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
AnaMariaVR2 QA's negligence threatens Ranbaxy's future revenue US Food and Drug Administration (FDA) 1
SteelMaiden What does the future hold for nuclear power? Coffee Break and Water Cooler Discussions 10
Sidney Vianna Future ISO 9001 Variations: "Lighter" and "Higher Level" Versions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Marc An iMac "Touch" in the future? After Work and Weekend Discussion Topics 2
Sidney Vianna The ISO 9000 ecosystem - a clear(?) vision for the future of the ISO 9000 family ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
rob73 Possible future of IFU (Instruction for Use)? EU Medical Device Regulations 3
M The near future will be better? Coffee Break and Water Cooler Discussions 9
B CQI-14 (Consumer-Centric Warranty Management) certification required in the future? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
A If the estimates are correct Mexico could win a future Soccer World Cup Funny Stuff - Jokes and Humour 19
Marc Riding the Electromagnetic Wave of the Future World News 4
U eVaro-Future Hybrid Sportscar World News 0
Sidney Vianna The Future Structure of ISO Management System Standards Other ISO and International Standards and European Regulations 61
R The Future of ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
A Advice for future QM (Quality Manager) in automotive Career and Occupation Discussions 29
Marc The Future - G.E.?s Breakthrough Can Put 100 DVDs on a Disc After Work and Weekend Discussion Topics 0
Marc The Future of Harley-Davidson World News 74
D Current Medical Device under 9001 Excluded from future ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
U The Future of Quality Management Philosophy, Gurus, Innovation and Evolution 13
Wes Bucey Consulting ? Is it in YOUR Career Future? Career and Occupation Discussions 63
W ISO 13485 Certification for Future Business ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Future hopeful lead ISO Quality Auditor - Please help me here on my quest Career and Occupation Discussions 31
C "Lean" and the future........ Lean in Manufacturing and Service Industries 2
