Gage Block Calibration Requirements question
thekellyg
Hello all,
We have a set of gauge blocks that are used to verify tools and tooling in our machine shop. They have been sent for 'calibration' in the past and my question is this: Since there is virtually no way for them to be out of calibration, do we need to spend the money for a yearly third party calibration? Thanks in advance for your guidance!
Stijloor
Re: Calibration question
Hello all,
The calibration/verification interval is determined by your organization.
If there has been no wear on the blocks, you could expand the interval to 2 years.
Hello all,
Why do you think they can't be "out"? Gauge blocks do wear outside of limits - not that you'd notice, but they do change "grade"...
thekellyg
Thanks everyone! They are actually used very little so I'm pushing it to two years for now. :agree1:
P
PaulJSmith
Yup. We have a couple of sets that only go out every 5 years. As Somashekar noted, should it be questioned, you could use previous years' data to support the change.
I
Illek
Something to consider when figuring out the calibration cycle is how much paperwork and data would you have to dig through to investigate if the blocks ever came back out of calibration. Example: Do you want to 2 years of records or 5? Could be part of your risk analysis for changing the cycle. We had a high cycle item get contaminated and corrode. It was not fun to investigate especially when there was a computer system change in the middle of the data trail.
crager34
On a similar note, depending on how the OD Mics are used, they can be pushed out to every 2 years also. Just make sure the length standards are calibrated. more frequently.
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
W Gage Block Interim Test Guidance General Measurement Device and Calibration Topics 5
W Uncertainty Components for Gage Block Comparator Measurement Uncertainty (MU) 2
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
B Tolerances on Gage Block Grades General Measurement Device and Calibration Topics 2
V Gage Block Minimum Grade. General Measurement Device and Calibration Topics 2
C Gage Block Measurement - Home made gage blocks at 1" intervals IATF 16949 - Automotive Quality Systems Standard 7
T Gage Block 8D Project - Incorrect Gage Block Orientation General Measurement Device and Calibration Topics 9
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
apestate How to keep gage block sizes unknown for R&R factors of MU General Measurement Device and Calibration Topics 11
B Gage Block Tolerances - Grade B Gage Blocks General Measurement Device and Calibration Topics 6
G Gage Block Search - Looking for gage blocks that are 12, 24 and 40" General Measurement Device and Calibration Topics 5
J Grade 3 accuracy requirement for gage block General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
