Gage Block Calibration Requirements question
thekellyg
#11
Thanks everyone! These blocks are stored in their protective case at all times and only used once a year to verify calipers so there is essentially no 'wear and tear' on them.
hogheavenfarm
#12
We have the same situation, and I have set the gage blocks at 5 years as well. It is more cost effective to simply buy new blocks every 5 years than calibrate more often for us. We do not need high grade blocks, and we use them for about 50 calipers. Handling is important however, gloves and great care when using.
Project Man
#14
Re: Calibration question
Thanks everyone! They are actually used very little so I'm pushing it to two years for now. :agree1:
We have a set of gage blocks that are only used to calibrate shop tools. Our calibration interval is 5 years for the gage blocks. We have been through several ISO audits and our interval has been accepted every time.
BradM
#15
Yes! You need to be having gauge blocks evaluated. Depending on their construction material, they can expand and contract (hence the reason they have ? tolerances).
Wear is just one factor that can affect gauge blocks.
Just asking...
When you get new gauge blocks, do you have the old gauge blocks verified before disposal?
We have some pretty nice gauge block sets with probably 10 uses per month. In reviewing the measurement data returned with them, the gauge blocks do change over time. I can see this because we have gauge blocks that are verified annually that aren't used (long story.. but I digress). Most gauge blocks shrink, but I do see them expand also.
BradM
#16
That's good. Auditors shouldn't be dictating your intervals; your process requirements should.
If the gauge blocks are stable and well within tolerance at the scheduled calibration, there is no need to do it sooner.
Like I said, the main thing I do is watch for trend. When a gauge block gets near 75-80% of tolerance, I have it replaced.
hogheavenfarm
#17
Actually I do check the old ones, but since I do not have equipment here capable of precise enough measurement to calibrate them, it does me little good, except to maybe try to stretch the calibration interval a bit, but even that is risky due to the uncertainty level of my equipment. We do not dispose of them, I have several sets sitting here on my shelf.
#18
Scary, eh? It could well be that the auditor has not much idea, of course. You realize that...?
Shannon3288
#19
I just sent out a set last week and they looked pretty good to me even though they were quite old. I completely expected to open up the box and put away my cert. Unfortunately the 1" block failed and they rejected them. I did however just order a new 1" block with a certification and will be just sending that back with the set and then it will pass. Don't let their good condition fool you. It was however only off from its actual allowable wear by .000022.
BradM
#20
A question... you state you have equipment to check them. Do you think your equipment is sensitive enough to pick up changes?
just wondering... you may not have the precision to measure and certify their accuracy; but possibly assess drift? Then, you can extend the certification of them out more. If the blocks are stable; good. If you are detecting drift, maybe time to send them in. You can use the data from the calibration vendor to assess your measurement system.
Just a thought.
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
W Gage Block Interim Test Guidance General Measurement Device and Calibration Topics 5
W Uncertainty Components for Gage Block Comparator Measurement Uncertainty (MU) 2
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
B Tolerances on Gage Block Grades General Measurement Device and Calibration Topics 2
V Gage Block Minimum Grade. General Measurement Device and Calibration Topics 2
C Gage Block Measurement - Home made gage blocks at 1" intervals IATF 16949 - Automotive Quality Systems Standard 7
T Gage Block 8D Project - Incorrect Gage Block Orientation General Measurement Device and Calibration Topics 9
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
apestate How to keep gage block sizes unknown for R&R factors of MU General Measurement Device and Calibration Topics 11
B Gage Block Tolerances - Grade B Gage Blocks General Measurement Device and Calibration Topics 6
G Gage Block Search - Looking for gage blocks that are 12, 24 and 40" General Measurement Device and Calibration Topics 5
J Grade 3 accuracy requirement for gage block General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
