Gage Block Grade 1 - Calibration
Hello there !
I have a gage block set Grade 1 which is due to calibration. My boss does not wanted to send out to be calibrated because she wants to save money. She has decided to do it internally. However, We do not have a master part to compare with but we have a Zeiss CMM machine. Would it be valid to measure the gage block with the Zeiss and use the MPE vale of it to calculate the Uncertainty ? Our Zeiss has two mode available : Optical and Probing, I am thinking to use Optical mode ?
can someone help me on this task ? I have not do it before and I am not 100 % sure if may works ?
Thanks a lot !
Johnny Quality
Chrifer,
What do you use the gage block set for? How often do you use it? How often is it calibrated?
You may be able to justify extending the calibration frequency.
Hello Johnny,
thanks for your replay. I am new in the company but I have been told that it is the first time that the gage blocks need to be calibrated after they bought. They are not used very often, very rare I would say. They use the gage block to calibrate other instruments such as electronic calipers, gage drops and electronic micrometers that's all.
the calibration of gage block must be done every 5 yes according to the system.
Scanton
Wearer of many hats
I have a carbide gauge block set that I use for micrometers, calipers etc that I send away to a UKAS lab for calibration every 5 years.
I'm not being rude, but how much are you actually saving each year by not sending your gauge block set off to be calibrated every 5 years, and how does this cost compare against the resource you will use doing it yourself and the uncertainty of measurement you will now be throwing into the mix?
In my experience trying to cut these types of costs will end up biting you (individually and your company) in the backside and will cost you more in the long run.
dwperron
There is an old saying in Calibration:
"You can use a gauge block to calibrate a yardstick, and a yardstick to calibrate a gauge block, but only one of them is the right way".
With Grade 1 gauge blocks you are talking a tolerance of ±2 µinch.
For a valid calibration your CMM would need to be 4 times more accurate.
Your CMM is nowhere near accurate enough, even if you were just doing comparison readings to a master gauge block set.
That's why you use gauge blocks to calibrate a CMM, not a CMM to calibrate gauge blocks.
As for extending the calibration, I would not go longer than 5 years. Even when not used, the steel in hard gauges like gauge blocks can change value due to changes in their molecular structure.
Ron Rompen
Chrifter: I am in much the same position as you are - with the financial constraints on our company due to Covid and the chip crisis (now finally resolving) we are cutting corners as much as possible.
I have revised our calibration procedure to show the CMM as the 'master' reference, and it is calibrated annually by a 3rd party. Our gauge blocks are used to verify/calibration calipers and micrometers, and the CMM is used to validate the gauge blocks - because of the nature of our business, and the tolerances that we work to (± 0.010mm is considered a very tight tolerance for us) this suffices.
In most QMS systems, (ISO 9001 IATF 16949) it is left to YOU to determine how you set up your calibration frequency and methods. Make sure it is clearly documented, and make sure there is traceability back to a NIST standard.
Ron Rompen, Yes exactly, I will try to calibrate them with the Zeiss machine we have in the lab. My boss totally refuses to send the Gage block to any calibration center. So I will give a try and measure with the Zeiss and use its MPE ( Maximum Permissible Error ) to calculate the Uncertainty somehow. However, I am aware that the Uncertainty might be larger in this case. What method do you use to calculate the uncertainty (U) and how ? Thanks a lot
Scanton, It is not that expensive, I actually found a very good price to do so, but unfortunately my boss does not understand that. She believes is so simple and can be done with a caliper or micrometer in our lab :( . I told her several times that there is a procedure to follow and it is normalized as well and still she doesn't care at all. So, I will give a try with the Zeiss machine and see what I can obtain . However, I am fully aware that Uncertainty will be larger in this case thought .
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
V Gage Block Minimum Grade. General Measurement Device and Calibration Topics 2
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
B Gage Block Tolerances - Grade B Gage Blocks General Measurement Device and Calibration Topics 6
J Grade 3 accuracy requirement for gage block General Measurement Device and Calibration Topics 2
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
T Gage Block Calibration Requirements question General Measurement Device and Calibration Topics 19
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
W Gage Block Interim Test Guidance General Measurement Device and Calibration Topics 5
W Uncertainty Components for Gage Block Comparator Measurement Uncertainty (MU) 2
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
B Tolerances on Gage Block Grades General Measurement Device and Calibration Topics 2
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
C Gage Block Measurement - Home made gage blocks at 1" intervals IATF 16949 - Automotive Quality Systems Standard 7
T Gage Block 8D Project - Incorrect Gage Block Orientation General Measurement Device and Calibration Topics 9
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
apestate How to keep gage block sizes unknown for R&R factors of MU General Measurement Device and Calibration Topics 11
G Gage Block Search - Looking for gage blocks that are 12, 24 and 40" General Measurement Device and Calibration Topics 5
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 9
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Faro Arm, Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
PQ Systems Recipe for Success! 10 Ingredients for a Healthy Gage Management System Using GAGEpack Software 0
D Gage Repeatability for Faro Arm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
PQ Systems Best Practices In Gage Management Using GAGEpack Software 0
PQ Systems Gage R&R - 3 Part Series Using GAGEpack Software 0
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Repeatability Type 1 Gage and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
