Gage Block Minimum Grade.
V
Van_H
What is the minimum grade a gage block should be to calibrate micrometers and Digital caliper verniers?
Micrometer, Resolution 0.00005 Accuracy +/-.00005
Vernier. Resolution .0005 Accuracy +/-.0005
justncredible
Re: Gage Block Minumim Grade.
I think it depends on what the MU for the gage is.
So whatever you use has to be able to have at least the original specs measurement uncernity.
CalRich
Generally, you want to maintain a 4:1 ratio for your master and gage being calibrated. You should reference the grades in ASME B89.1.9. if you don't have the standard, the grade specs are listed in Starrett and Mitutoyo catalogs (and the like).
Provided you are talking about 0-1" mics, you want to have gage blocks accurate to at least 12.5 millionths (0.0000125"), which would be ASME Grade AS1. This isn't considering any measurement uncertainty in the process. If it were me, I'd go one more grade better ASME Grade 0.
The AS-1 grade would be sufficient for the vernier caliper.
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
T Gage Block Calibration Requirements question General Measurement Device and Calibration Topics 19
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
W Gage Block Interim Test Guidance General Measurement Device and Calibration Topics 5
W Uncertainty Components for Gage Block Comparator Measurement Uncertainty (MU) 2
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
B Tolerances on Gage Block Grades General Measurement Device and Calibration Topics 2
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
C Gage Block Measurement - Home made gage blocks at 1" intervals IATF 16949 - Automotive Quality Systems Standard 7
T Gage Block 8D Project - Incorrect Gage Block Orientation General Measurement Device and Calibration Topics 9
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
apestate How to keep gage block sizes unknown for R&R factors of MU General Measurement Device and Calibration Topics 11
B Gage Block Tolerances - Grade B Gage Blocks General Measurement Device and Calibration Topics 6
G Gage Block Search - Looking for gage blocks that are 12, 24 and 40" General Measurement Device and Calibration Topics 5
J Grade 3 accuracy requirement for gage block General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
