Gage Block Search - Looking for gage blocks that are 12, 24 and 40"
gpainter
Looking for gage blocks that are 12,24 and 40". I have been able to find 12" steel,but no other bigger than 20". Would like carbide. Would prefer not to wring smaller blocks. Thanks in advance. I have checked Starret, Fowler, Brown & Sharpe, Davis and Travers. :frust:
Jerry Eldred
Have you asked if they could build you a custom length? I'm presuming that because you don't want to wring together, you need pretty tight tolerances which couldn't be achieved with wrung blocks. My first inclination in such a situation would be to request a custom build.
Al Dyer
Agree,
Custom ($$$$) build might be the only way to go. You might also want to consider the yearly calibration costs of a custom built block and the need for a backup block.
Good luck GP, keep us posted!:)
Ryan Wilde
I hate to say it, but there is no such block prebuilt. To have them made would probably cost thousands of dollars each (a good 20" block is SEVERAL hundred dollars, and they are set up to make them in quantity. Mind you that it can be done for a price, but the lead time will be long.
Another problem is that special sizes usually require a minimum of 4 be built (something to do with the lapping process was what I was told).
My suggestion would be to PERMANENTLY wring blocks together. For example:
24" - (2) 12" blocks
40" - (2) 20" blocks
Both sets should (must) be wrung and held with rods (use square blocks), using threadlocking compound on the threads to 'preclude adjustment'.
Most good dimensional labs should be able to measure the finished stack for you with an uncertainty of <100µin (at 20°C - your temperature and uncertainty may vary, offer void in some areas). The manufacturer may even be able to do this for you, and it would be much cheaper than being made of a continuous piece of metal.
More for the 'information' file:
Clean, well wrung gage blocks begin to go through a process of 'cohesion' in a fairly short time. Cohesion is the process of two separate masses sharing atoms. I've seen it in practice (purely accidentally - we couldn't get blocks apart with a rather large mallet - they had been wrung together for only two days).
Ryan
(Since you're in Indiana, and I lived/worked there in a purely dimensional lab until April, I can put you in contact with someone that can help you explore this further, and it is an accredited lab. I will not post the company in the forum, however.)
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
T Gage Block Calibration Requirements question General Measurement Device and Calibration Topics 19
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
W Gage Block Interim Test Guidance General Measurement Device and Calibration Topics 5
W Uncertainty Components for Gage Block Comparator Measurement Uncertainty (MU) 2
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
C Etalon gage block uncertainty General Measurement Device and Calibration Topics 8
B Tolerances on Gage Block Grades General Measurement Device and Calibration Topics 2
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
V Gage Block Minimum Grade. General Measurement Device and Calibration Topics 2
C Gage Block Measurement - Home made gage blocks at 1" intervals IATF 16949 - Automotive Quality Systems Standard 7
T Gage Block 8D Project - Incorrect Gage Block Orientation General Measurement Device and Calibration Topics 9
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
apestate How to keep gage block sizes unknown for R&R factors of MU General Measurement Device and Calibration Topics 11
B Gage Block Tolerances - Grade B Gage Blocks General Measurement Device and Calibration Topics 6
J Grade 3 accuracy requirement for gage block General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
