Gage calibration frequency, ISO and IATF - What are the requirements
guna8184
Hi Bull Dog,
Equipment manufacturer will recommend you to calibrate the equipment least once a year.
It all depends on your frequency of use and the precision and tolerance required by your organization..
But most importantly what is the frequency stated in your procedure
I've never seen such a recommendation for mechanical devices.
Frequency of use may or may not be relevant. What's important is observation of the "as found" condition when devices are calibrated. If a given device needs adjustment when calibrated, it's an indication that more frequent calibration might be necessary. On the other hand, if a device continually doesn't need adjustment, the calibration intervals might be lengthened.
What's important is that the calibration interval stated in the procedure is actually what's needed.
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 14
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
R EXTECH Oyster-10 Calibration Frequency (pH/mV/Temp gage) Calibration Frequency (Interval) 2
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
S Interesting Discussion Threaded ring gage calibration and tendonitis in the elbows General Measurement Device and Calibration Topics 8
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
S Calibration of a Coating Thickness Gage General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D Gage Calibration Tracking in MS Excel Calibration and Metrology Software and Hardware 9
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
K Gage Calibration - Corporate Scheme IATF 16949 - Automotive Quality Systems Standard 3
C Black Oxide Gage Pin Calibration Requirements General Measurement Device and Calibration Topics 4
X When a Gage is past the Calibration Due Date General Measurement Device and Calibration Topics 6
T Gage Block Calibration Requirements question General Measurement Device and Calibration Topics 19
C How to Clean Gage Blocks and Gage Pins prior to Calibration General Measurement Device and Calibration Topics 4
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Trusting Gage Manufacturer Calibration Certifications General Measurement Device and Calibration Topics 3
K Qualifications I need to adhere to for Thread Gage Calibration Calibration Frequency (Interval) 1
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
M Thread Gage Calibration - Who to use General Measurement Device and Calibration Topics 5
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
S Purchase Order requirements Gage Blocks sent out for Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
C Test Uncertainty Ratio (TUR) for Ring Gage Calibration Measurement Uncertainty (MU) 7
S Mechanical/Electrical Forces Gage Calibration Methods Calibration and Metrology Software and Hardware 1
M Calibration Cycle for Standard Iron & Steel Plate Gage General Measurement Device and Calibration Topics 17
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
C Gage and Calibration Software Comparisons Calibration and Metrology Software and Hardware 6
A Calibration Standards - Rod Standards vs. Gage Blocks Calibration Frequency (Interval) 2
C Adjustable Thread Ring Gage Calibration General Measurement Device and Calibration Topics 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
B Temperature Gage on an Oven was Out of Calibration Period General Measurement Device and Calibration Topics 15
F Process Monitoring Gage Calibration Requirements - 7.6.3.2 External laboratory IATF 16949 - Automotive Quality Systems Standard 1
R Calibration of a portable FARO gage portable CMM # F04L2 gauge General Measurement Device and Calibration Topics 6
J In-House Calibration Requirements - Use of Grade 2 set of gage blocks General Measurement Device and Calibration Topics 2
