Gage Calibration Stickers in harsh environments - Are Calibration Stickers Required
CliffK
#11
Re: "Calibration Stickers"
It's not uncommon. The sticker can just be used to let users know the calibration status, while the engraved number is a permanent identification allowing the calibration status to be ascertained if the sticker comes off. In such a case the sticker is a convenience, not a necessity.
Agree with the sticker as a convenience.
I just have a positive prejudice against having the same data in two places...
joshua_sx1
#13
Re: Gage Calibration Stickers in harsh environments - Are Calibration Stickers Requir
I have seen one semi-conductor company use barcode for identification & traceability of their measuring devices… once you scanned it, it’ll give you everything you need about that measuring devices e.g. calibration due date, result of the latest 3 calibrations performed, the person who performed the calibration, repair history (if there is), who repair it, even the supplier and the date when it was purchased is included in the date, etc…
Although it is a controlled environment since it is a semi-conductor production and they have practically no problem with sticker being washed-away (the sticker btw, is also some type of heavy-duty sticker – the one that cannot easily tear-off unless you intentionally tear it off)… and as their preventive, not only barcode sticker is attached to their measuring devices but the equipment unique identification number is also engraved into the measuring devices (wherever possible) where you can manually enter into their database and will give you the same information… quite systematic management there huh?
David DeLong
#14
In one screw machine plant where cutting oil seemed to be everywhere, the calibration system used oil based color coding to reflect the due date.
Once a measuring devise, such as a micrometer, has had its calibration confirmed, the old paint color was scraped off and a new color code for the next due date was applied with a tooth pick. It would take a few minutes for the paint to dry but it would actually stay on the instrument where a sticker would come off. I believe there were 3 colors with the combination of colors reflecting their due dates.
Today, I don't really think that the instrument would require a calibration sticker as long as the instrument was uniquely identified and complete records were attainable.
In a harsh environment such as a screw machining operation and the quality system required stickers, the color coding approach is a good alternative.
Bob the QE
#15
After reading these posts and seeing that these are all over a year old I thought I would ask the experts; have there been any new technologies in the area of labeling in harsh environments? One idea that I find interesting is the bar code with maybe a little twist for me (K.I.S.S):). I would be looking at a very simple type of label, ID # would really be all I need because that would tie back to the actual cert. The driver here is keeping the label attached, especially on ring gages and thread rings where you can't put anything through the middle. Do they make these types of gages with pre-drilled holes on the OD that you could put a tie wrap or wire through?
I always enjoy the feedback, info and ideas I get from the pro's here at the cove.:applause:
Jerry Eldred Calibration Stickers - Do we have to put stickers on every gage and all equipment? General Measurement Device and Calibration Topics 38
S Interesting Discussion Threaded ring gage calibration and tendonitis in the elbows General Measurement Device and Calibration Topics 8
R Master Gage Block Calibration (We have 2 sets) question General Measurement Device and Calibration Topics 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
S Calibration of a Coating Thickness Gage General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D Gage Calibration Tracking in MS Excel Calibration and Metrology Software and Hardware 9
K Height Gage Compensation Block Calibration General Measurement Device and Calibration Topics 1
K Gage Calibration - Corporate Scheme IATF 16949 - Automotive Quality Systems Standard 3
C Black Oxide Gage Pin Calibration Requirements General Measurement Device and Calibration Topics 4
X When a Gage is past the Calibration Due Date General Measurement Device and Calibration Topics 6
T Gage Block Calibration Requirements question General Measurement Device and Calibration Topics 19
C How to Clean Gage Blocks and Gage Pins prior to Calibration General Measurement Device and Calibration Topics 4
I Gage Block Calibration/Measurement Control Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Trusting Gage Manufacturer Calibration Certifications General Measurement Device and Calibration Topics 3
K Qualifications I need to adhere to for Thread Gage Calibration Calibration Frequency (Interval) 1
D New to Gage Block Calibration Reports Measurement Uncertainty (MU) 6
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
M Thread Gage Calibration - Who to use General Measurement Device and Calibration Topics 5
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
S Purchase Order requirements Gage Blocks sent out for Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
C Test Uncertainty Ratio (TUR) for Ring Gage Calibration Measurement Uncertainty (MU) 7
S Mechanical/Electrical Forces Gage Calibration Methods Calibration and Metrology Software and Hardware 1
M Calibration Cycle for Standard Iron & Steel Plate Gage General Measurement Device and Calibration Topics 17
A Grade 1 Block Gage Calibration Master General Measurement Device and Calibration Topics 2
C Gage and Calibration Software Comparisons Calibration and Metrology Software and Hardware 6
A Calibration Standards - Rod Standards vs. Gage Blocks Calibration Frequency (Interval) 2
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
C Adjustable Thread Ring Gage Calibration General Measurement Device and Calibration Topics 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
B Temperature Gage on an Oven was Out of Calibration Period General Measurement Device and Calibration Topics 15
F Process Monitoring Gage Calibration Requirements - 7.6.3.2 External laboratory IATF 16949 - Automotive Quality Systems Standard 1
R Calibration of a portable FARO gage portable CMM # F04L2 gauge General Measurement Device and Calibration Topics 6
J In-House Calibration Requirements - Use of Grade 2 set of gage blocks General Measurement Device and Calibration Topics 2
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
R 3 Wire Thread Measuring System - Gage Calibration General Measurement Device and Calibration Topics 8
5 Gage not calibrated to full use/range of the gage - Surveillance Audit - Calibration General Measurement Device and Calibration Topics 7
M Functional gage calibration (GD&T gurus) General Measurement Device and Calibration Topics 3
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
