rlsavard
I would like to clarify some methods we are using versus what I think we need to do.
We are a job shop using Swiss Style CNC Lathes. We frequently have jobs with +/- .0002. We use mics (plenty of varieties), calipers, ring gages, plug gages, pins, indicators, etc.
Right now, we have a "shift change over" form that each machinist completes at the beginning of his/her shift. One of the steps to follow on this form is to validate the accuracy of your mics against a .2500Z pin that everyone uses ONLY for this purpose. As for the plug gages, we have a laser comparator that checks the pitch and other dimensions of the threads in a matter of seconds, so we use that before a gage is used for any job. We do the same thing with plug gages in order to verify the accuracy of ring gages as well.
There is some discussion around the shop about how we should calibrate all tooling and gages at our shop. Some higher-ups just think you need to have a color sticker on the equipment that means it's within calibration. My issue with this is, they've said that you don't need to individually identify each micrometer set, caliper, etc. It seems to me you need to be able to identify each piece so you know when to calibrate that specific piece. Their belief is that if you calibrate every single mic at the same time, you're good to go. Although it does make some sense, it just doesn't seem kosher to me.
Ideally I would prefer to mark each device (MIC0001, MIC0002, CAL0001, CAL0002, etc.) I still like the color coding sticker option, but thought it might be a good idea to write the calibration expiration date inside the sticker. To me, this doesn't seem like a huge endeavor but would raise fewer auditors' eyebrows.
One thing we're focusing on is to keep this SIMPLE. We want an effective system, but we don't want to over think it and create unnecessary additional work.
As for pin gages, we use the infamous For Reference Only stickers since we have so many. Each machinist double checks the pins he/she is using, but it is not documented anywhere. Is this a problem? Do we need any pins to be identified as calibrated or can we just stick with the FRO approach? We could easily use the laser comparator to check the accuracy of the pins, but that would take quite some time given the quantity we have. I don't want to spend all that time calibrating each pin, since not every pin is used regularly, if at any point during the calibrated time period.
I'm looking for any thoughts about the system we're using vs the system I envision. If anyone would care to share their system I would appreciate that as well. Thanks for your help!
