E
eturkan
Hi Gage R&R experts..
I could not get an answer in reply to another post.I did a Type 1 study as a prep to Anova.
I have 4 questions.
1. For Bias we must use the real parts and what if they change.
I need to do a study on OD of ptfe o-rings using flat micrometer and a tapered aide. Master value of OD using vision systems increases 0.02% which caused a higher bias. If I use post test master value, bias drops to 4%.
2.For stability gage blocks or real parts? What is the common interval for measurements for a flat micrometer that has 6 months calibration interval with no problem in past?
3.Linearity: Gage Blocks or real parts?
AIAG MSA: Due to process variation, select 5 parts that covers the entire operating range of the gage. What is process variation? Potential of the gage being used in other processes or variation within a process?
4. Type II Minitab Results
I know that we use %TOL if our CPK is over 2.5 but do we still use it at times when it is higher than %GRR?
I have 4 questions.
