Gage Out of Tolerance Procedure
d-wright
Ok here it goes,
We were audited last week and our auditor asked us what we do if a gage is out of tollerance but still within customer tollerance specs. Now the person that did this job before me put some stickers on the gages that stated that the gage was ok because it did not exceed the 10% tollerance allowed by us. We have no idea how they figured out the 10% so we did not have a good answer for her. I have for some time now been trying to come up with a procedure to handle gage out of tollerance conditions but have had no luck. Nobody seems to know anything about this procedure. she also wanted to see an assessment of the gage out of tollerance. Does anyone have a suggestion or can tell me how they handle gage out of tollerance conditions and assessment? Thanks in advance :thanx:
K
Kevin H
Re: Gage out of tollerance procedure
A short list of steps would be:
First, you need to hold or quarantine all product measured with the suspect gauge before anymore is shipped to an internal or external customer. Then, in general, you need to be able to determine how far is the gauge out of tolerance and what was measured with that gauge from the last known point it was in tolerance to when it was found out of tolerance. From there you have to evaluate if any measurements made would be out of specification for your customer considering how far the gauge is out of tolerance. If you're lucky and they would not be, I'd update test results as needed for in stock material and document all actions taken.
If you're unlucky and have material that has shipped to the customer you should (ISO/TS requires that you notify them) notify them and arrange for use with deviation, or return.
Fianlly, you should evaluate your gauge calibration/checking to determine if the interval needs to be shortened or if other actions could be taken to eliminate future out of calibration issues that would potentially produce non-conforming product.
d-wright
Sounds good, Problem is that we have approx 1000 jobs that we run and we have no way of tracking what job that particular gage was used for. Good news is that we have not yet had a gage out of tolerance that would be out for our customer.
If you don't mind my asking, Setting the assessment aside, What do you do if you have a gage that is out of manufacturers tolerance but still in for the customer? The person that did my job before me put a sticker on the cert that stated:
"The "out-of-tolerance" condition of ____% did not affect our product quality since it's within our minimum of 10% allowable tolerance" then the QA manager signs it.
I have no idea how they figure out the % or what formula they would have used. Any ideas?
jfgunn
I would say that the tolerance that matters is that which is acceptable for your use or customer requirements. The manufacturer's tolerance is useful, but the tolerance that matters is the one you assign - as long as you document how it was assigned.
As a calibration services provider, I run into your issue all of the time. Most companies do not have any way of knowing which gage was used on which product.
In an ideal world, you would have a gage database where gages are issued for jobs and every use gets tracked. You have to weigh the cost of tracking this information versus the benefit of having the information.
As for how the previous QA guy came up with the 10%, who knows! He probably looked at his typcial calibration data and saw that gages never seemed to be out by more than 10%. He then set the arbitrary value and ran with it becuase it was the easiest thing to do.
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
P Strange Gage R&R results for a Caliper (Tolerance Method) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C P/T % of a gage R&R to 0 MMC Tolerance study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Roundness Tester Gage R and R Frustration - Tolerance range of 20 microns Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Gage R&R - Percent of Tolerance or Percent of Variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Accepting/Rejecting Threads WITHIN Gage Tolerance General Measurement Device and Calibration Topics 2
P Out of Tolerance Gage - Justification for not Recalling Product Misc. Quality Assurance and Business Systems Related Topics 7
M Honest GR&R (Gage R&R) Tolerance Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A %Total Variation & %Tolerance - Differences in Gage R&R Forms and Templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage Resolution vs. Tolerance Manufacturing and Related Processes 5
B Addressing Lots that were measured with Out of Tolerance Gage Pins Nonconformance and Corrective Action 5
D Gage R&R %Tolerance NDC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R % Gage R&R Based on Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Gage R&R 10:1 Tolerance to Gage Discrimination Rule Explanation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Gage R&R - Tolerance - APQP Forms Disk from the AIAG - Formulas IATF 16949 - Automotive Quality Systems Standard 3
smryan Gage R&R Tolerance - Manufacturer's stated tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Part Tolerance and Equipment Accuracy of thickness gage General Measurement Device and Calibration Topics 1
I Gage Error vs. Dimensional Tolerance - Accuracy needed for measurement equipment Measurement Uncertainty (MU) 10
Q Tolerance Set Plugs to Calibrate Thread Ring Gage - Question General Measurement Device and Calibration Topics 4
C Gage R&R @ 10% - Does that mean you should cut your tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
0 Gage R&R Total Tolerance question - Use the full process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
B Calibration Accuracy vs. Gage/Part Tolerance General Measurement Device and Calibration Topics 4
P Calculating Gage R&R with Part Tolerance instead of Total Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Gage R&R - Using Tolerance method, or part to part variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Gage R&R when using Tolerance - Really bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D One-Sided Tolerance Gage R&R Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Gage R&R - Calculating by Specification Tolerance vs. Study Variation - Differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G How to complete gage R&R when you have only a single sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U How do part tolerance and gage tolerance interact? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Gage Tolerance vs. Process Parameter Tolerance - Process qualification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Gage pin clearance on close tolerance - Hole size is ?.8746 ? .0001 General Measurement Device and Calibration Topics 9
P Gage R&R - What does the % tolerance says about my Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
B ANOVA Gage R&R % Tolerance and Preference Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Full Scale Tolerance - How to apply full-scale accuracy specification to a gage? General Measurement Device and Calibration Topics 4
