Gage R&R Acceptance Limits - General features on a component
K
KWB64
:confused:I know it varies depending on the criticality of the feature that the gage will be used to evaluate, but for purposes of this dicussion, let's assume we are measuring general features on a component. What would be the maximum Gage R&R percentage you would accept? Beyond this point, the measurement system would be rejected until improvments can be put in place. I am working with general mechanical gages such as micrometers, calipers, etc.
Thank-you
Sturmkind
The AIAG Measurement Systems Analysis manual used to state (1st-3rd editions):
0-10% Acceptable
10-30% may be acceptable based upon the importance of apploication...
Over 30% error -measurement system needs improvement...
The other stipulations were that no point should exceed the calculated Range Upper Control limit and the number of distinct categories (ndc) should be an integer greater than 4.
The 4th edition restates the above in more detail on page 78.
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
P Gage R (no reproducibility) - Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Acceptance Criteria for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Ajit Basrur Gage R&R - Acceptance Criteria Based on One Customer - URGENT Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Attribute Gage R&R: Acceptance criteria for CrossTab Method? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Gage R&R - Acceptance Criteria for Linearity, Bias, and Stability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
