Gage R&R and Fliers
  • Thread starter jane_ackerman - 2010
  • Start date
We have just completed a 16 characteristic, variable R&R on an automated gage (2 operator / 3 trial / 10 piece).
In all actuality, these are 16 separate R&R's.
Each operator had 1 flier. These filers were not on the same characteristic, nor were they the same sample part number.
I am confident that it is acceptable to replace one flier on a study.
My question is for hypothetical future reference:
How many readings can be replaced (per operator and/or total) in a single study before they are no longer considered "fliers"?
I can't find anything on this in the MSA 3rd Edition.
Thanks, Jane
Thanks, Jane
There is no hard-and-fast rule because each situation is different. When the results tell you that something's not right, you have to investigate and find out what it is. "Fliers" are measurement results that are statistically unlikely to happen under "normal" circumstances, and might be the result of random error or assignable cause(s). You shouldn't just throw them out and recalculate unless you're reasonably sure that they're just randomly spurious. In the case you cite, I would first look for relationships between the various operators' errors.
Cause was assignable
I absolutely agree with you - it must be a special cause to throw any flier out.
In this case, we found debris on the part surface that was being measured. Being only a 5 micron tolerance, this made all the difference in the world. The part was cleaned with a lint free material (suede) and re-checked.
Thanks for your input!
You're welcome. Be sure you use what you learned to provide guidance for people who have to make those measurements in "live" situations.
Rob Nix
I am always concerned about "fliers", and we never "throw them out" without knowing the reason. If you get just one per study, remember that the study is a small sample of a future population.
If the flier is the result of a burr, or contamination, or improper location / alignment on a fixture, it tells you something about the measurement system's weaknesses (which might possibly be alleviated by an additional step in the instructions). Later, in production, that occassional errant reading could result in a costly incorrect decision.
The key is - know the reason. If you don't, it will likely come back to bite you later.
Dave Dunn
It seems in this case that the cleaning method could be incorporated into the documented measurement procedure to eliminate the root cause and help to assure that your R&R is going to represent future output of the measurement system.
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
apestate Inexpensive Gage Blocks for small aerospace startup shop General Measurement Device and Calibration Topics 1
