Ummm.....Looking just at part #10, you have > .05mm variation on an ID only 26mm? On a CMM?
I would look at (in order):
- Is your program taking multiple readings as Miner describes, or just one ID? It's an automated CMM...you should be measuring literally hundreds of datum per second. Check your program. If you measure in different places each time, and your part varies that much (circularity), no wonder you're failing GRR.
- Is the part stable, or is it jiggling during measurement?
The demo I would run to show customers was to take off my wedding ring, put it on the stage, and hit "go".
In a couple of seconds, I got hundreds of ID measurements, hundreds of OD measurements, best fit circles for ID and OD and circularity for both.
Are you just using measurement #1 for your GRR?
Then I would put a penny on the stage, and we would measure the width of Abe Lincoln's knee (did you know he's in there?)...that's how a CMM should be giving you the data...not 0.05mm error.
(Note...his knee is less than 0.05mm wide...)
