Many R&R techniques compare the variation of the gage to the variation of the process. For highly capale processes, the ratio may be "poor' by the boiler plate metric (<10%, etc) but the practical impact when using the gage for acceptance (actual variance or std dev) is minimal as total variation relative to the tolerance limits is small and the process is extremely capable. You dont give up much even if youghten the tolerance limits. On the other hand, it will cause you issues if you use the gage for process control (SPC) as the gage variation will mask process shifts/changes.
On the other hand, you should also be careful of how you select your samples as they nee to accurately reflect the population. If they dont, then comparing the gage variation (std dev) to outside assessments of the variation (stdor dev) of the process may be a better technique.
David
