Gage R&R - Destructive Test - Pharmaceutical industry - Tablet hardness
Dan Armstrong
Is it possible to do a gage R&R on an instrument that performs a destructive test? I work in the pharmaceutical industry and I'm looking to determine the reliability of an instrument that measures tablet hardness by cracking them.
K
KenK - 2009
In general you have two choices when dealing with a destructive test:
1 - find homogeneous parts (same batch or similar) and treat them as pseudo repeats. This can be pretty tough. You'll need to use a nested design instead of a crossed design since these are not true repeats - MINITAB provides a tool for this anlaysis.
2 - find some way to take repeated measurements without destoying something. For example, with a pull test hang weights from the device rather than actually pulling until a break occurs.
Ken K.
Tommy
Evaluating Destructing Testing
Find Dr. Donald Wheeler's "Evaluating Measurement Systems". Published by the SPC Press. Excellent paperback covering the necessary means for evaluating destructive testing.
JuanAgos
Re: Gage R&R
Of course which if it is possible to be made, single that you need to use the method R&R that analyzes the variation part to part.
Do you know it method ?
Any question, contac me via email.
bye
I guess this a good topic to expose my lack of knowledge on the subject as any.
1- Is this machine controlled by the operator or is it automatic, where all the operator does is to place the pill in the fixture and push the button. If it is similar to a Rockwell hardness tester then the operator has no control other than viewing the results on a dial indicator or digital readout.
Doesn't seem like a gage R&R would accomplish anything for the gage relibility.
2- I would think relibility would be stated by the manufacturer, and verified periodically by calibration.
3- I like the idea stated earlier about using within part variation. Sounds like it might give a little more information on the rebility of the process.
Dan Armstrong
On the surface, it would appear that the operator just places a tablet into the machine and pushes a button. However, the test is very sensitive to the orientation of the tablet when it is placed into the tester, therefore an operator that is diligent in placing the tablet correctly may get different results than someone that is less diligent.
It appears then that the fixture is the initial "special cause" for variation and merits further investigation. Have you performed a gage R&R using three different operators? If so, what were the results? With this data you can determine the need for mistake proofing the fixture.
Dan Armstrong
That brings us back to my original post - how can I perform a gage R&R using three operators if the tester destroys the samples? I already know that there is variation from tablet to tablet, so I can't assume that a sample is uniform.
Restated, my problem is this - how can I determine the percentages of total variation that are attributable to gage and operator variation if I can't retest the same samples with different operators?
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Destructive Tensile Pull Test Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R - Destructive Test - Tensile Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O How to do Destructive Test Gage R&R - Rupture Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Destructive Testing GR&R (Gage R&R) - Track tester - JMP Program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S How do I do Gage R&R in Destructive Testing? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B We found a Gage R&R for Destructive Methods Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Destructive Gage R&R method for a glass factory study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Gage R&R Destructive Tests - Tensile tester to check for paper strength Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
