Gage R&R experts please review these studies
ScottK
Not out of the crisis
I'm not an expert in Gage R&R yet. I know what it's for but am not very experienced in analyzing the results.
Attached is a pdf with two studies I did yesterday. I would appreciate any feedback and thoughts on the results.
Thanks!
ScottK
justncredible
Sorry did not see the 2nd one, the operator variation is pretty high, is it a verneir mic or a indicator mic? .0003 with a mic on the same part makes me think the operator does not have the "feel" needed to use a mic. Try a two click thimble mic. You should not see that much of a range. With a thimble mic i would expect .0002 from operator to operator, more than that one of them has a bad techneic. Watch how they use the mic, same part as close to possible same place on part. Does the part have taper? If so that would induce more variation than just the gage and operator. Also note temp, and lenght of time they hold the mic and part. COE is a big factor for mics and parts.
A gr&r is a way to look at the gage and operators ability to measure a feature. At 20%, 80% of the time you are not getting a true accurate measurement.
Attached is a Minitab ANOVA analysis of your data.
The caliper may be suitable if you can address the operator to operator differences. Operators 2 & 4 measure distinctly higher than the other 3. This may be due to technique, pressure, etc.
The micrometer results are marginally acceptable but may be improved by studying the method used by Operator 5. This operator has distinctly less variation within their results. There are also distinct operator to operator differences, probably due to pressure. Did all use the thumb ratchet?
ScottK
Like so with the friction thimble:
http://www.mitutoyo.com/TerminalMerchandisingGroup.aspx?group=1092
On the part there is no taper and it's not a diameter - it's flat to flat.
I'm not doubting one or two of them need improvement on technique. I've been diddling with the data and in both cases if I remove one or two of the appraisers I get FAR better results on the AV and R&R.
So I guess that tells me who needs some work.
Thanks for the feedback. :thanx:
ScottK
cool, thanks!
I really need minitab.
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
