Gage R&R for an On-Line Device - Continuous Monitoring Dew Point Sensor in a Furnace
G
GoKats78
During a corporate audit the question was "Has a Gage R&R been conducted on the Continuous Monitoring Dew Point Sensor in the furnace?"
The answer was...No...
No one is sure how to conduct such an R&R on such a device...or if such a test is even needed.
Someone, please provide some insight!
Stijloor
Re: Gage R&R for an On-line device
A few questions:
What was the reason for the audit?
Did any of the corporate auditors cite a specific requirement or did they feel that it was a "nice to have" thing?
Stijloor.
G
George Weiss
Side-tracked:
I am obviously confused, and interested in this question/post/comment.
The dew point device I am familiar with is what reports the dew point in a refrigeration system like a refrigerator.
The temperature and humidity values which cause dew, like 100 R/H of warm breath in cold air.
The temperature at which 100 R/H occurs varies with water vapor concentration in the air.
I was not aware of the need for this monitoring in a furnace.
Is there a dew point of a specific metal vapor or other?
I would first determine if such a feature of the furnace was needed.
You commented that a gage R&R of the dew-point monitor has not been done.
In your development of the process using the furnace, was a gage R&R done?
Reviewing this, if it was completed might suggest something further.
Is/are there requirement(s) for gage R&R in your application? process Standard or other?
Sturmkind
Re: Gage R&R for an On-Line Device - Continuous Monitoring Dew Point Sensor in a Furn
GoKats78;
There may be more of a need to establish validation of the in-line sensor rather than a formal GR&R. Over time the comparison of readings between the in-line sensor and an off-line sensor should be highly correlated. The mechanics for that are well summarized here: http://www.coleparmer.com/techinfo/...dewpoint-accuracy.htm&ID=973&referred_id=2730 and I have no vested interest whatsoever in these companies or web-sites.
Best of Luck!
K
Kevin H
George, many furnace processes used in heat treating metals utilize atmospheres generated either by mixing industrial gases such as nitrogen and hydogen, or nitrogen and other additives such as methanol and or natural gas. Other options include disassociating ammonia into nitrogen and hydrogen or cracking either natural gas or propane over a nickel catalyst at high temperatures - depending on conditions the reaction may be exothermic or endothermic. The gases produced are usually referred to by the name of the reaction.
One of the controls for these types of furnace atmospheres is the dewpoint in the furnace. This may be analyzed periodically using an instrument such as an Alnor dewpoint meter, or monitored continuously via an aoutomatic dewpoint measurement. Dew points will tell you if your atmosphere production equipment is operating properly, and can indicate if their is an air leak in the furnace that could affect final properties of the material being processed. This is true for both ferrous and non-ferrous parts.
Dew point control may be used while annealing, carburizing, and neutral hardening, and during sintering of PM parts. A typical dewpoint for the incoming industrial gas nitrogen would be -80 dgrees F. You won't see that in most furnaces, because many are belt or other types of furnace that operate at slight positive pressure to minimize infiltration of oxygen from the air surrounding the equipment. Their will be air infiltration, and some of the oxygen in the air will react with hydrogen in the furnace atmosphere to produce water vapor, which will increase the dew point in the furnace.
Having said all that, I'm not certain of any way to run a gage R & R on a continuous monitoring dew point instrument - I'd be more interested in the calibration and verification protocol, and corrective actions for variation from verification checks. If it got way out of calibration, you'd probably be producing bad parts from your process - oxide coatings, low hardness, poor sinter, etc.
dbzman
Kevin is right on the money. Gage R&R is used to determine if a measurement device will have the capability of measuring a certain product. Is the device capable of measuring the product?
I would ask the auditor why he believes that the device should be evaluated using Gage R&R. Is this from a PPAP that was developed? Sometimes if you list a device in a PPAP the auditor will expect a gage R&R to be performed on it.
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Gage R&R on an EOLT (End Of Line Tester) - Include Reference or not? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
