Gage R&R for Checking Fixture with multiple check points
tgranger
I need some help. I need to conduct a MSA on a checking fixture (for a vehicle carpet) with multiple check points (31). Some are gap and flush, and some are cut-out or hole diameter. I am told I need to do a study of 30 parts. My question: Do I pick a single check point on the fixture to base my study on, or do I simply do a pass/fail type of study. I'm confused. Can anyone help? (3 operators, 3 trials, 30 parts........is this correct?)
Tom
sauhiew
Re: Gage RR for Checking Fixture
It's actually 10 parts, 3 operators, 3 trials. You should check all 31 points because they check different quality characteristics unless some characteristics have direct effect from others. For example in stamping so-called stack-up tolerance, the center of a hole can be affected by hole location, bending distance, and angle of bending.
Dale D. Barnes
Re: Gage R&R for Checking Fixture
I agree that you should do each location on the gage separately and not as one gage. The question is are your readings variable or attribute. If it is a Go/NoGo type of gage then you can use two operators and use as few as 20 parts but I use 50 parts. But if you take variable readings then you would have to do the 3x3x10 (3 operators, 3 trials, 10 parts)
Tom
I'm assuming that (a) the fixture has been validated/certified and (b) it's strictly an attributes thing--you put the carpet on, and it either fits or it doesn't.
If this is true, then you just need to do a attributes study, which is covered at length in the AIAG MSA manual, Third Edition. If it's not true, please post back with more information about what the check fixture is actually supposed to do.
tgranger
The fixture has not been certified. Submitting the MSA to the OEM will assist me with its approval. Once I place the carpet on the fixture, some cut-outs may align within tolerance band (+/- 2mm) or some may be outside the tolerance. So, the carpet may fit on the gage, but 3 out of 31 holes are not within tolerance (ex. 2mm outside tolerance). Each hole has its own reading (gap and flush....so there are two variables per check point - vertical gap between the fixture and carpet and distance horizontally between the carpet hole edge and the tolerance band). The inspector has to record (2) readings per check point. Is it feasible to place the carpet on the fixture, visual inspect each check point, and record GO / NO GO for the entire carpet (attribute study).
tgranger
I have a spreadsheet setup to check (1 point). Can I modify it to check all (31), or do I need special software to handle this job?
These may be silly questions, but I'm learning. Thanxs.
tgranger
Do you use a programmed spreadsheet or some other software?
M Checking a male taper using a female air gage fixture - Air Gaging question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
Q What data to record when an operator is checking a part on a gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F 1. Suggest a Gage for Checking Rounding of Gears 2. When to conduct Stability Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
