Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance
W
WKHANNA
I have a customer who is requesting the PPAP contain a GR&R for the gauge pins used to inspect a hole ID (.165 +/- .005") identified as a Statistical Tolerance.
Is it at all practical to conduct a Gauge R&R on gauge pins?
Re: Gauge R&R for gauge pins?
Pins can be used as either attributes or variables devices and MSA can be performed on either.
W
WKHANNA
Thank you for the link, JLang.
Though we typically use GAGEtrak 6.7 for MSA's & R&R reports, the Excel spreadsheet is a very useful reference.
Jim, appreciate the input.
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
C How to Clean Gage Blocks and Gage Pins prior to Calibration General Measurement Device and Calibration Topics 4
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
A Gage R&R on Involute Gears (Over 2 pins measurement) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Addressing Lots that were measured with Out of Tolerance Gage Pins Nonconformance and Corrective Action 5
Proud Liberal Using Three (3) Gage Pins to Check Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
H What are the pros and cons of working with gage pins? General Measurement Device and Calibration Topics 10
J Using Gage Pins - Inside diameter - Interference fit General Measurement Device and Calibration Topics 4
D What is a good way for identification of gage pins - Machining Department General Measurement Device and Calibration Topics 17
G Gage Pin Dilemma - Is there an "easier" way to put our gage pins in our system? General Measurement Device and Calibration Topics 8
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 2
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
