Gage R&R for Multiple Fixtures
TLAKE39
Hi All,
I am conducting a Gage R&R on four different fixtures that are all measuring the same, single dimension. I took 30 parts and had 3 different operators measure them on each fixture but I think that is too many variables. The main purpose of the study is to see how closely each fixture measures the same part so that each company using the fixtures will be able to (theoretically) get the same numbers upon inspection.
Given your experience, what do you think would be the best way to conduct this study? I'm not too familiar with complex gage studies like this.
I am operating with Minitab 14 but could download a trial of 17 if that makes it easier.
Thank you in advance!
Todd
Minitab 16 added an Expanded R&R Study that will allow you to add the fixtures into the study. And alternative, if the Operator impact is insignificant, is to replace the operators with the fixtures in a standard study.
G Gage R&R Across Multiple Sites in a Company Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
Y Gage R&R for multiple measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Multiple Variation Gage R&R for Automated Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P GR&R (Gage R&R) Across Multiple Configurable Test Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Gage R&R - Sensor Tester with Multiple Operators and Multiple Sensor Test Channels Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E GR&R (Gage R&R) with Multiple Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Multiple Fixture Automated Vision System GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B For GR&R (Gage R&R), is multiple testing of the same sample necessary? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T Gage R&R for Checking Fixture with multiple check points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Commercial gage scheduling software package that can store multiple PPM histories General Measurement Device and Calibration Topics 7
rivariva Number of decimal places : Gage R and R Using Minitab Software 1
J What Device Should I use for Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Minitab formulas regarding anova gage r&r Using Minitab Software 1
T Borescope Mentor Visual IQ Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R IATF 16949 - Automotive Quality Systems Standard 2
D HELP gage card not popping up Using GAGEpack Software 2
F How often should Gage R&R's be updated? Is there a recommended time-frame? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W What is dimensional layout of the gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Does a gage used for a visual verification need to be calibrated? Manufacturing and Related Processes 7
T Gage Numbering Using GAGEpack Software 6
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
PastorBee13 Attribute Gage R&R with no bad samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage type and data base maintainence Using GAGEpack Software 2
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Faro Arm, Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
PQ Systems Recipe for Success! 10 Ingredients for a Healthy Gage Management System Using GAGEpack Software 0
D Gage Repeatability for Faro Arm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
PQ Systems Best Practices In Gage Management Using GAGEpack Software 0
PQ Systems Gage R&R - 3 Part Series Using GAGEpack Software 0
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Repeatability Type 1 Gage and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
