avalon
Greetings,
Question: We have a test machine with 13 pressure trandsducers. Eleven are 0-300 psi, two are 0-1000 psi.
The customer has requested we do a GR&R of them prior to running parts through the machine.
What is normally done is using a pressure calibrator, apply known pressures for the 0-300 psi trandsducer, one at 0 the other at say 250 psi, and take a reading from the analog display. It is done 10 times for each device. The same is done for the 0-1000 psi transducer; 0 and 800(?) psi.
My question is what GR&R procedure/formula (standard) is best used and how should it be interpreted? On the one hand it would seem a simple Gage R study would be sufficient, yet we need to make sure the analog display is accurate. Since Gage R only requires a tolerance, it seems it would not satisfy the need to ensure the analog display is reading accurately. Sorry if I'm using incorrect terms.
Thanks in advance for your help.
