Hi
Im jumping in into this thread becuase i have some questions about this aswell or maby get some feedback on how i will conduct the test
Im set to do a MSA study on our leaktester, but im confused if im going to do a variable or a attribute MSA.
If i do a attribute i need to know how capable my equipment is so i need to preforme an capability study to se the machine's spread otherwise i dont know if i can trust the figurs that is comming out. Nevertheless
this is what the tester do just says ok or not ok out from the limits it is set for
but if i do a variable MSA on it i need to make some coolers that i know how much they leak,
that is no problem for 2 of the tests but for the internal test it might be little tricky (The tester preformes 3 test during the cycle, ExternalA, B and internal between A and B)
My instinct says that i should do a Variable one with the leaks just above the leak limit that the program should find so i dont do to big leaks so that the results is not trustable
so i will make 5 leaking products for each side A,B and (Try) internal and add 5 non leak, i will use the non leaking coolers for all test with the leaking A resp. B and Internal so the sum will be 10 for each test run, i will run these 5 times ending up with 50 meassurings X 3.
I will then do this at three different times to reproduce the operator (Cuzz the operator cant effect the test itself) and inbetween these 3 times they will run other product this only to se if the machine itself has any variance
Do you think this is a good way to approuch this ??
Hope to get answer on it
Thanks for a great forum Tommy
