Gage R&R Form in Excel for Calculating Gauge R&R - Attached
automoto
#61
Hi all.
Could you, please, help me, how to set up GRR for destructive testing method?
I have done pull test method on the samples.
I can do pull test once on one sample. Then the sample is destroyed.
How can I set up GRR study?
Is it correct to prepare samples by the following?:
30 samples measured by 1. operator
30 another samples measured by 2. operator
30 another samples measured by 3.operator?
The samples are made from the same process (1 welding machine), produced one by one during short time.
How can I calculate EV, AV, GRR correctly?
Zuzka
Zuzka,
Please refear to attached file for informations of how to perform MSA for destructive testing.
Regards
Z
Zuzka
#62
Zuzka - can you post your data? It will be easier for us to help you with this if we can use your data to demonstrate the concepts
Hello.
This is the file with the measured data.
The data were measured by 3 operators.
The samples were destroyed after the tests, so each measurings were made using the new samples from the process.
Could you, please, help me, how to evaluate GRR for this type of measuring?
Z.
Z
Zuzka
#64
you cannot calculate Pp from this data*. Pp is the actual process variation as quantified by the standard deviation: Pp = (USL-LSL)/6*SD
BUT Pp is not directly useful for Gage R&R. It is the SD that is directly useful. If you have historical data that you know is representative of your actual process variation you can substitute that SD for the PART VARIANCE instead of calculating it from the GAGE R&R study parts.
*IF your R&R study parts were randomly selected from a portionof the process that exhibited the full range of variation that your process has historically demonstrated, then you could use the study SD to calculate Pp. BUT most inexperienced people don't select their R&R parts in this manner.
Thanks for the explanation.
This is the file with the measured data from my MSA study.
How would you explain these results? Was this study set up good?
Z.
Mr.Happy
#65
Hi Z,
I noticed that in your Study results the NDC is only 3.:(
This should be at least 5.:agree1:
This could mean that the range in dimensions of the parts is to small or the resolution of your measuring equipment is not precise enough?
Z
Zuzka
#66
Hi Z,
Thank you for your answer.
I will try to improve the measurement system for these parts and I will change the sampling process.
Could you help me, how to explain the results of TV?
Which value is the best for TV? Is there some "good" value for TV and also for PV, which are recommended?
Zuzka
V
vishalkifi
#67
Re: Gage R&R Form in Excel for calculating gauge R&R attached
Hai everybody,
one of my customer has given the following point on MSA,kindly elaborate
and send the 4th edition format
"GRR is done to monitor measurement capabilities however R&R is calculated in terms of total variation instead of part tolerance resulting low % GRR. "
Thanks in advance
VISHALKIFI
#68
Hai everybody,
Thanks in advance
VISHALKIFI
You don't say who made the observation and under what circumstances, but whether percent of variation or percent of tolerance is used depends on the purpose of the measurement system. If it's used for process control, percent of variation should be used, and percent of tolerance is used if the device is used for inspection.
Not sure what you mean by "send the 4th edition format."
V
vishalkifi
#69
Hi.
Marc Smith
Thanks for your quick response.
During one of customer audit, this point was register as a NC
We had done MSA for all the major critical parameter but auditor said that you have done G R&R to monitor measurement capabilities
but R&R is calculated in terms of total variation instead of part tolerance resulting low % GRR.
I couldn't understand the auditor point of view
also I need 4th Edition MSA xls Format to close this NC
Pls do the needful.
by
VISHAL KIFI
T Gage R&R Excel .xls form and SPC Xbar and R template (lost it.. ) Excel .xls Spreadsheet Templates and Tools 13
I Gage R&R Form - Excel or other - Calculations Questions Excel .xls Spreadsheet Templates and Tools 13
A What should be the contents of the New Gage Introduction Form ? General Measurement Device and Calibration Topics 3
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
H Gage R&R Data Collection Form w/ Appraisers Names, Number of Parts, Number of Trials Document Control Systems, Procedures, Forms and Templates 2
M AS9100 Gage R&R Form Needed Document Control Systems, Procedures, Forms and Templates 6
M Gage R&R form for 2 operators 10 parts and 3 trials needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
B Gage calibration form needed Document Control Systems, Procedures, Forms and Templates 8
P Gage Repeatability (1x1x10) form - 1 part measured 10 times by 1 appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Q Gage R&R lite? This form only uses two operators measuring five parts one time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Attribute Gage R&R Form - Long Version - AIAG's MSA Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 35
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
