Gage R&R Frequency - How often to perform the GR&R?
K
Kennydu1981
Hi All:
In recent audit, the auditor ask us to show the MSA plan which means how often we will check the GR&R status. He required us to check the GR&R regularly, in yearly basis or something like that. I was looking for this requirement in MSA AIAG manual, frankly speaking, I did not find out where to define this requirement in the book. so can anyone help to point out where defines this requirement in MSA AIAG manual? or what's the rule of the MSA regularly check?
Thank you.
Measurement System Analysis is not the same as calibration, so you do not necessarily repeat it on the same frequency.
When establishing a frequency, look for opportunities that might affect the variability of the measurement device (not the bias as in calibration). Some items that might affect variability might be:
  • A change in the experience level of the operators
  • A change in the measurement method (e.g., change in measuring shaft diameter from a random diameter to a average of the max/min, or to the max diameter, etc.)
  • New fixturing (for CMMs, automated test equipment, etc.)
  • New model of gage
  • Change in measurement environment
  • Refer to the fishbone chart in the AIAG MSA manual for many other possibilities
You may be able to get away with a statement that you will review the measurement process on an annual basis for changes that might impact the MSA results and will repeat the MSA as required by this review. You will probably have to document the criteria that you will use to trigger a repeat of the MSA.
bobdoering
Stop X-bar/R Madness!!
Theoretically, there is no time function to Gage R&R. If performed correctly, it should not have to be "renewed". Gage R&R answers the question "Is this the correct gage for the job." Calibration answers the question "Does this gage still measure correctly" and does have a time function (wear, etc.)
  • New model of gage
I would never state that I would perform gage R&R to a time function, but I would encourage performing gage R&R's at the point in time that the gage system changed, as in the list above. Automotive will sneak in annual gage R&Rs by asking for annual PPAPs. The reason why they do this (the trusting souls that they are) is because they feel you may have made changes on the above list and did not analyze them at the time - or did not realize you made a change when you did. I understand why they do it, but, that is not the gage R&R function. It is more of a change control issue. Can't blame it on the tool. :cool:
Not exactly; it's "Is this the correct measurement system for the job?" because of the operator variable.
If you've documented your criteria for repeating GR&R, it's been my experience that the original gage studies can be used for annual PPAP submissions, but you never know, given the capricious nature of automotive PPAP reviewers.
bobdoering
If the proper choice of the variation of potential operators is captured (inexperienced to experienced), it should have been accommodated. It is designed to capture the measurement "system": the part, the gage, the operator. That is why I agreed with the operator level on the list. If the parts used to be only measure with the device in the QC lab, and now you want to use it on the line, you should redo the gage R&R and - as Dr. Phil says - see how that is working for you. (I would have still used a shop operator for a GR&R in the lab, unless it was a CMM-like device, just to capture the range and understand the influence of the operator)
So painfully true. :cool:
W Gage R&R study frequency - How often should a Gage R&R be performed? Capability, Accuracy and Stability - Processes, Machines, etc. 8
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
D TS 16949 Gage R&R Frequency Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
T Frequency of Gage R&R and Measurement Uncertainty General Measurement Device and Calibration Topics 19
A Determining Gage R&R Frequency Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Gage R&R Frequency required by TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 33
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
R Gage R&R Frequency - Are your GR&R's on a set schedule? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Grade 2 Gage Block Calibration Frequency? Calibration Frequency (Interval) 6
R EXTECH Oyster-10 Calibration Frequency (pH/mV/Temp gage) Calibration Frequency (Interval) 2
T TS 16949 Requirements: Frequency of Gage R&R Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
E What are the requirements, including frequency, of Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
