Gage R&R (GR&R) Brain Teaser
W
wmeister
Brain Teaser for all you readers out there:
If you start a process (variable-continuous) and determine the process is capable. Then do a process capability study with which includes the production gage which shows an acceptable Cp & Cpk (lets say 2.0 - 3.0+).
Pick One:
A. Now I do a gage r&r study.
B I did a gage r&r before I did the process capabilty study
C. Don't run a gage r&r study
E. What the heck is a gage r&r
--> Tell me why!
Re: Gage R&R Brain Teaser
The correct approach is B.
The measurement variance (s^2) is additive to the actual process variance (s^2). So, your observed process capability as shown by your study includes the measurement variation. Ideally, you should verify that the %GRR (not P/T Ratio) of the gage is low enough to provide an accurate estimate of the true process capability.
Benjamin28
I'd delegate answering the question to the lead auditor and resume reading dilbert cartoons.
If, however, the lead auditor chose other than option B.) I would put him on a conference call with Miner and let them debate the matter.
ScottK
Not out of the crisis
I pick C because I really don't have the resources and time to do gauge R&R studies except for very special cases - in which case I have to do all the legwork and number crunching myself.
Duke Okes
If the process is capable, why run an R&R. The capability study includes variation due to gage and operator (if done correctly), and if the process is capable then the measurement system is not contributing enough variation to worry about.
This is an applications viewpoint, not a theoretical one. We need to put our resources where they will be most valuable, not do something because it is the typical way.
John Nabors - 2009
If I had a crappy calibration program and poorly trained inspectors I would say B and do an R&R every time a capability study was performed, but since I have a very robust calibration system and an experienced and well-trained crew, I have to go with C with one exception: if I were still incarcerated in the accursed automotive industry and I was PPAP'ing a new part.
cuadra - 2010
I agree with Miner, the answer is B.
The measurement system variation always underestimates the process capability, but in the other hand, one cannot assume that a good process capability implies the measurement system is capable of achieving the target quality objectives.
The analytical approach to the answer is simple. First, one can find the equation that relates P/T as a function of both %R&R and Cp. Second, from the equation, one can easily conclude that a capable process doesn’t always imply that a capable gage was used. A nicely centered process with a small process variation could be measured with a lousy measurement system and one can still achieve acceptable process capability indexes (Cp and Cpk).
bobdoering
Stop X-bar/R Madness!!
This would be true with a device with bad resolution. It would make most parts appear exactly the same - where as a device with better resolution would show more significant variation - maybe not so centered. Take a yardstick, for example... :notme:
Fact is, Gage R&R specifically answers the question: Is this the correct gage for the application? If you have not suitably answered that question before you used the gage for any reason, then you are already starting at quality level TCE. :cool:
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
apestate Inexpensive Gage Blocks for small aerospace startup shop General Measurement Device and Calibration Topics 1
