Gage R&R = Interpretation = Needs Improvement?
I am attaching a gage R&R from an AIAG based system and asking for some help interpreting why, with a % R&R of 94 and 99 there is a staement directly below stating that the system needs improvement?
Page one of the spreadsheet is for one gage, and page 2 is for another gage.
same operators, and parts measured.
Any help would be appreciated. This is something I am not comfortable with.
James
James
Two things jump out: if the %R&R is >30, you're going to get that "needs improvement" message every time. That's considered the upper limit for acceptability. The other thing is something that I see a lot in average-and-range studies, and that is UCLr violations--one of the operators' measurements have exceeded the upper control limit for ranges. The cells that contain the ranges are formatted to show only two decimal places, so the actual numbers weren't showing up, even though they were reflected in the calculations. I reformatted the cells to show four places, and highlighted the violation (and the upper limit). The reformatted sheet is attached.
Thanks Jim - Obviously I am way off on these things.
Silly me, I assumed that something approaching 100% reliability and repeatability was good.
But what you are telling me is that the closer to 0% reliability and repeatability is good.
I guess I'll do some more study and see what other questions come up.
The R&R number is a representation of the proportion of the variation present in the system that may be attributed to measurement error. Although this is something of an oversimplification, it's saying that there is x amount of detected variation, y% of which is the result of measurement error. So lower numbers are good.
R P-value and interpretation of ANOVA Gage R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
H Type 1 Gage Study Interpretation Question Using Minitab Software 7
R Gage R&R Interpretation - Prototype gage - Would like some advice. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
