Gage R&R K1 constant - Changing of the constant affect the gage study result?
match_stick82
May I know whether the changing of the constant affect the gage study result?
For K1 I found 2 constant for a sample of 10 sample, 3 trial, 3 operator with the exising template I have.
Which of these is the correct constant?
1) K1= 0.5908
2) K1 = 3.05
Is it possible to find the relevant documented prove of these constant?
match_stick82
1) K1= 0.5908
2) K1 = 3.05
From "Measurement System Analysis (2003) by Mario Perez- Wilson", the K1 constant for 10 samples, 3 trial, 3 operators is 3.55.
How did the number 3.55 come about?
It is stated that the Confidence Interval used is 99.73% and K1 = sigma/d2.
The formula used is similar to most references on this forum but it affects my result by 6 times than K1=0.5908.
Why is there such a big variation to the K1 constant?
Howard Atkins
Forum Administrator
The constants were changed between the 2nd and 3rd editions.
Please see the threads that Atul has referenced above for answers to your questions
match_stick82
I have read the thread posted.
I still cant understand the BIG change.
Majority of the gage R&R in the company failed because of the 6 times difference in the constant.
Please enlightened.
bleoj69
1. On the constant K1:
- MSA 2nd ed. uses 5.15/d2*
- MSA 3rd ed. uses 1/d2*
- Perez-Wilson uses 6.00/d2*
2. Will it have impact on GRR result?
- Not significantly. As long as you use the same sets of constants (K1, K2, K3) from the same GRR form. Do not use the different constants coming from different GRR forms interchangeably.
The constants themselves do not affect the measurement variation (StdDev), but the change from 5.15 * StdDev to 6 * StdDev does make GRR as a percent of tolerance worse. The change does not affect GRR as a percent of Process Variation or as percent Contribution.
3 K1 K2 K3 constant of Gage R&R - Please advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Constant for thread gage calibration with the three wire system General Measurement Device and Calibration Topics 7
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
