Gage R&R - Looking for help in deciphering this report
Ron Rompen
I will leave it to others to interpret your analysis reports, however I will say that the ultimate summation (R&R) of .001 is, although an EXCELLENT score, highly suspect.
Looking at the data you provided, I would immediately suspect that the measuring equipment you are using does not have sufficient discrimination; the tolerance range is 0.003, and the reported values are in increments of 0.0005 (with only one operator reporting values to that increment).
On the good side, the parts DO seem to span the entire range of the accepted process (always useful).
Anyone else?
(BTW, don't be embarassed for asking.....most of us have to ask for help on a regular basis...that is the whole idea of the Cove; quality professionals (and me) helping each other :)
K
KenK - 2009
The key metrics for this analysis are in the Summary in Excel cells V29 (%R&R) and X29 (%Tolerance).
%R&R is an index of measurement precision compared to the process variation. Acceptable %R&R is very important if the gage is used for SPC, process capability analysis, and process improvement (DOEs, etc...).
%Tolerance is an index of measurement precision compared to the tolerance. Acceptable %Tolerance is very important if the gage measurement is compared to a specification, such as in end-of-line testing.
For a capable process (Cp>1, the %R&R will always be larger (and less acceptable) than the %Tolerance. This is one reason many prefer to use the %Tolerance, since it provides a smaller value.
The acceptance criteria for both are:
<10% - Acceptable
10-30% - May be acceptable based upon importance of application, cost of measurement device, cost of repair, etc.
>30% - Not acceptable
In your case, the %R&R is 21.44% (MINITAB average & range method comes back with a value of 19.79%) which is in the "maybe be acceptable" range. Consider how vital the measurement precision is.
The %Tolerance is 35.87%, which is not acceptable, BUT the tolerance -/+ values and nominal value are entered into the spread sheet in a way that leads me to beleive that this is a one-sided lower spec. The nominal is 0.3 with a lower spec limit of 0.297. Your spreadsheet doesn't appear to be able to handle a one-side spec.
MINITAB can handle a one-sided spec, and returns a %Tolerance of 63.52% using a multiplier of 5.15 (as an FYI, the automotive industry has now started using a 6.00 multiplier, rather than 5.15). It uses a formula of 3s/(Xbar-LSL), where s is the standard deviation associated with R&R, and Xbar is the average of all measurements.
This is certainly not acceptable, but considering it is larger than the %R&R, I would suspect that either your process is not capable, or that your Gage R&R study did not produce a good estimate of the process variation. If the later is the case, you should replace the denominator of the %R&R calculation with 6s, where s is the overall standard deviation calculated from a good process capability study with sufficient sample size (n=100 or more).
Another metric that is utilized in GR&R studies, but not in your spreadsheet is the "number of distinct categories". This provides an assessment of your gage's discrimination or resolution. This value should be 5 or greater. The ndc value from MINITAB using your data with the average & range method is 6, which is acceptable.
The Rbar charts typically should be in control, but as you can see, all three opertors have out-of-control ranges. This means that the operators are having problems measuring those parts consistently - more variation that is expected.
The Xbar charts typically should be out-of-control. They show the observed variability of the parts measured, but the control limits are calculated using only the measurement error - as opposed to the part or total error. If the measurement error is small, the observed variation should be much larger than the width of the control limits. In your case the %R&R is 21.44%, which is marginally acceptable. This results in the Xbar chart being less out-of-control than might be expected.
KenK's comments are correct, but you should repeat the study under consistent rules.
If the entire study were done with measurements to .001, the gauge resolution is not adequate. Some of the measurements were .0001. This level of resolution is adequate. However, since the bulk of the study was at the .001 level of resolution, most of the ranges were zero. Many of the calculations are driven by the range, so it appears to be artificially low.
I question the validity of the GRR results, and recommend that you repeat the analysis using .0001 resolution.
B Looking for IndySoft (Gage Insite) help Calibration and Metrology Software and Hardware 4
T Looking for holtest/bore gage...help - Range of hole measured 3.6 - 4.0" General Measurement Device and Calibration Topics 1
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
M Looking for a Round Taper Gage with Graduations General Measurement Device and Calibration Topics 9
Q Gage R&R Report - Looking for a GOOD example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Gage Block Search - Looking for gage blocks that are 12, 24 and 40" General Measurement Device and Calibration Topics 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
