Gage R&R Methods - ANOVA, AIAG, 6sigma Xbar/R, GM - Which to Use
Serge B.
Hi everybody
Can someone tell me when to use those different ways to calculate GR&R?
Results can vary a lot between all those methods.
Thanks in advance!
Re: G R&R ANOVA, AIAG, 6sigma Xbar/R, GM.. methods
The ANOVA and Xbar/R methods will provide similar results. The Xbar/R method is easier to calculate by hand, but if you have a computer available, the ANOVA method will provide more accurate results, including the effect of the Operator x Part interaction.
However, both methods will lead to the same decision, unless your gage is very borderline. For example, one may give you a %GRR of 30.1% while the other gives 29.9%. The results are similar, but when the cutoff point is 30% max, they will lead to different decisions.
Serge B.
Is there anyway a more appropriate method acoording to the type of measurement performed or gage used?
I mean such as an automated gage Versus a manual one and so on..?
The two methods used by AIAG were based on the assumption that the gage is a manual gage and is subject to Reproducibility variation.
In the case of automated test equipment, there are three scenarios.
The first is that you have multiple test stations in a single ATE machine. Treat each station as an operator and the reproducibility will be the error caused by differences in stations. The repeatability will be the within station error.
The second scenario is multiple ATE machines with a single station. Treat each ATE as an operator and the reproducibility will be the error caused by differences in ATE machines. The repeatability will be the within ATE error.
The last scenario is a single ATE with one station. Perform the MSA as if you are using a single operator. I would recommend performing additional repeat measurements to compensate for the loss in reproduced measurements.
Having said all that, the same comments regarding ANOVA versus Xbar/Range methods still apply, and they are still the appropriate tools to use.
T Variables Gage R&R - Minitab v14 - F statistic Calculation - ANOVA - Methods validity Using Minitab Software 2
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
R Gage Identification Methods in a Job Shop Calibration Frequency (Interval) 8
S Mechanical/Electrical Forces Gage Calibration Methods Calibration and Metrology Software and Hardware 1
S Can someone help me to understand GR&R (Gage R&R) analysis methods? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Gage R&R confidence limits - Bootstrap methods or MLS (modified large-sample) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B We found a Gage R&R for Destructive Methods Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
