Gage R&R/MSA for In Process Measurement System in a Turning Machine
beikmar
looking and searching this forum i got a lot of information but not yet sure how to manage the following situation:
we are installing a new production line with a few machines using a in process measurement system to adjust the diameters for turning operation. Question: what is the right approach to demonstrate our OEM customer that the measurements are reliable ? The part is given into the machine by the operator, clamped and then automatic process starts....
FYI: We have Minitab and can use this to do any calcs
So - thanks in advance for any quick feedback as our customer is in tomorrow ;-)
beikmar
bobdoering
Stop X-bar/R Madness!!
Re: Gage R&R / MSA for In Process measurement system in a turning machine
Somehow you need to get output of what the machine measures. The most clever thing to do would be to prepare 10 parts with variation within the expected process range. Program the lathe to touch off on the parts (without turning) and record the data. It would be a Gage R, which, if repeated over several intervals to get stability, should work. You can also use different operators, in case there is any operator dependence on loading the chuck. If so, you can do a regular gage R&R.
One of the down sides of this approach is you miss some of the error from vibration, surface finish, etc. that it will see during turning.
Just a suggestion - hard to ponder without the machine and its details in front of me....
T Are MSA?s (Measurement System Analysis) Process or Gage Based? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
S MSA (Attribute Gage R&R) on our process monitoring points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J AIAG MSA and Gage R&R - What does the Process Variation % R&R truly mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Gage R&R Criteria on page 78 MSA Reference Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
C Gage R&R/MSA for PPAP - Our product has no variance Statistical Analysis Tools, Techniques and SPC 9
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
2 MSA when neither Nested nor Crossed Gage R&R is Applicable Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Runout Gage R&R - MSA on Roundness Tester - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
bobdoering Dr. Wheeler is back with his thoughts on MSA and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Gage Run Chart Analysis - Page 105 MSA manual 3th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA and Gage R&R for Measuring Microscope Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Output of Nested MSA Gage R&R - Is this possible? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P AIAG SPC Manual (ver.1) Interpretations related to Gage R&R (GR&R) and MSA IATF 16949 - Automotive Quality Systems Standard 8
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q Internal Testing and Calibration Laboratories - MSA, Gage R&R and Control Plans IATF 16949 - Automotive Quality Systems Standard 2
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Significance of X chart in AIAG MSA sheet for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Z Determining how many measurement devices need gage R&R? MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
H MSA Excel .xls worksheet that includes GR&R (Gage R&R), Bias, Linearity, etc. Excel .xls Spreadsheet Templates and Tools 15
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D When is MSA (Measurement System Analysis) appropriate on a custom built gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z MSA - Gage R&R Study Analysis - SAMPLE - Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
R MSA and Gage Tracking Software that complies with MSA 3rd Edition Quality Assurance and Compliance Software Tools and Solutions 6
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K MSA 3rd Attribute GR&R (Gage R&R), no operators - Air decay test systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
