Gage R&R/MSA for PPAP - Our product has no variance
christinaparkway
I work for an injection molding company. I am doing all he documentation and studies required for a PPAP. Our product has no variance. I am "failing my studies because I do not have any parts under my nom. Has anyone had to deal with this issue? Do I have to hand make parts so they look good in the study? :mad:
Re: Gage R&R/MSA
Welcome to the Cove. :bigwave:
I suspect that it's not that your product has no variation; it's that your measurement system isn't sensitive enough to detect it. Tell us more about what you're measuring (characteristic, nominal, tolerance) and what you're measuring with.
christinaparkway
Re: Gage R&R/MSA
It is a small 8mm ball that we check with a micrometer. 8mm +/- 0.025. Last study parts measured 8.013 to 8.018. The study is being kicked back due to lack of variance in process. They kicked back the study stating lack of variance. Guessing it's because we are not 25% low, 25% high, and 50% nom. I haven't ran across an issue like this before. :frust:
christinaparkway
Re: Gage R&R/MSA
reply wouldn't work earlier. See below for my response. I forgot to add it's the O.D
Re: Gage R&R/MSA
From here it's hard to say what they might be complaining about. I assume it's a customer who rejected the study. They might be concerned about the process not being centered on the nominal, but that's not an MSA issue. Did you also do a capability study on the feature?
christinaparkway
Re: Gage R&R/MSA
Yes, the document submitted was contained MSA, R&R, and the capability results.
christinaparkway
Re: Gage R&R/MSA
also, we are using the anova graph in mintab to track everything.
Re: Gage R&R/MSA
How do the capability results compare (mean, ranges, etc.) with the MSA data? Are you sure you used parts for the R&R that were representative of the process spread?
Matt33
When you gathered your parts (8mm balls) for the study, did you gather them across the typical production process? (As opposed to consecutively produced.)
Sean Kelley
I have worked in injection molding in the past and there was some variation in that process. We used what was called a microview which basically was a micrscope on a monitor with calibrated rotary micrometers that were much more accurate than a handheld micrometer. A toolmakers microscope would also work well. Taking parts at the startup when it was a little colder would yiled different variation than when it warmed up and even different than if it ran for 8 hours. Also fiberglass in some plastics will wear certain types of molds if they are made of aluminum or soft steel vs hardened steel. Not sure if this helps but just some thoughts.
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Gage R&R Criteria on page 78 MSA Reference Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
2 MSA when neither Nested nor Crossed Gage R&R is Applicable Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Runout Gage R&R - MSA on Roundness Tester - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
bobdoering Dr. Wheeler is back with his thoughts on MSA and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Gage Run Chart Analysis - Page 105 MSA manual 3th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA and Gage R&R for Measuring Microscope Capability, Accuracy and Stability - Processes, Machines, etc. 5
T Are MSA?s (Measurement System Analysis) Process or Gage Based? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
M Output of Nested MSA Gage R&R - Is this possible? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P AIAG SPC Manual (ver.1) Interpretations related to Gage R&R (GR&R) and MSA IATF 16949 - Automotive Quality Systems Standard 8
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q Internal Testing and Calibration Laboratories - MSA, Gage R&R and Control Plans IATF 16949 - Automotive Quality Systems Standard 2
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Significance of X chart in AIAG MSA sheet for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Z Determining how many measurement devices need gage R&R? MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
H MSA Excel .xls worksheet that includes GR&R (Gage R&R), Bias, Linearity, etc. Excel .xls Spreadsheet Templates and Tools 15
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D When is MSA (Measurement System Analysis) appropriate on a custom built gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z MSA - Gage R&R Study Analysis - SAMPLE - Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
R MSA and Gage Tracking Software that complies with MSA 3rd Edition Quality Assurance and Compliance Software Tools and Solutions 6
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K MSA 3rd Attribute GR&R (Gage R&R), no operators - Air decay test systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA (Attribute Gage R&R) on our process monitoring points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
