Gage R&R MSA - Variation, Tolerance, Variance by different methods
Blaest
Can someone give me a hint please..
Conducting a MSA, evaluating the results:
• A&R, GRR Variation related to TV (Variation)
• A&R, GRR Variation related to Tolerance
• ANOVA, GRR related to TV (Variation)
• ANOVA, GRR related to TV (Variance)
The above methods give me way different GRR values, and I do not know how to handle this!
I do understand that ANOVA is preferred above A&R
I do understand ANOVA, TV related to Variation is not additive
I do understand ANOVA, TV related to Variance is additive
I do understand a good measurement system should be GRR<10%
Example:
1000mm +/-10
TV=1,085
ANOVA, Variation related to TV: GRR=27,9%
A&R, Variation related to Tolerance: GRR=9,2%
According to ANOVA the variation is too high, but compared to A&R it is less than 10%
Why should I not use this measurement system as the Variation related to Tolerance indicates?
Blaest
Re: GRR MSA: Variation, Tolerance, Variance by different methods
I partly found my answer,
If the Gage is used for Product Control -> %Tolerance
If the Gage is used for Process Control -> %Variation
So far so good,
If I use the Gage for Processs Control and use ANOVA I have the options:
• ANOVA, GRR related to TV (Variation) = 17,9%
• ANOVA, GRR related to TV (Variance) = 7,8%
Variance is ok - Variation is poor!
How should I evaluate this Gage?
• ANOVA, GRR related to TV (Variation) = 17,9% This is % Study Variation or better % Process Variation
• ANOVA, GRR related to TV (Variance) = 7,8% This is % Contribution
Use the % Study Variation (%SV) or % Process Variation (%PV) to determine suitability of the gauge.
% Contribution is not currently used to determine whether the gauge is suitable, but to determine the major source(s) of measurement variation in order to take action to improve the measurement system.
Blaest
Thanks Miner,
I would be able to have:
• A&R, GRR Variation related to Tolerance > 10%
• ANOVA, GRR related to TV (Variation) < 10%
According to:
I would have a gage that is:
NOT OK forProduct Control
OK for Process Control
That makes no sense to me,
Would I be wrong to assume that both would need to be OK to used for Process Control?
Or should I interpret this differently?:confused:
This scenario could happen when you have an incapable process, that is, where the process variation is much greater than the specifications. Under this scenario, you could have a gage that is acceptable for process control, but not acceptable for product control.
Fortunately, this scenario is not to common.
Blaest
Thanks Miner,
And you are right, that is my situation,
The reason is that I select my Parts to spread across the measuring range of the gage, for exampel a caliper 0-150mm
I am experimenting with uncertainty budget(GUM/VDA) and evaluating the gage over its range rather than at a specific dimension/tolerance (I migth very well be off ground here, but logically it makes sense to me..)
See Topic: 68299
(I am not allowed to post a hyperlink)
In that case, only % Tolerance has any meaning. The % Study Variation was rendered meaningless since the samples are not representative of the process.
Blaest
That makes sense..
What I am using is:
EV in unit (like 0,021mm)
AV in unit (like 0,19mm)
These values do not depend on the characteristics or the specifications.
These values would relate to the Equipment and the Appraisers alone.
I transfer EV & AV in units to GUM calculations.
Statistical Steven
Statistician
Bottom line is, you should use it! The bottom with %GRR as it relates to total variation is that if the part to part variability is small then your measurement system looks poor and if the part to part variability is high, your measurement system might look better. When you have specification, that is the preferred method of GRR for MSA studies in my opinion.
Example:
1000mm +/-10
TV=1,085
Blaest
Thanks for your input..
I do not have the statistical background to back me up - so I rely on logical thinking, this forum and intuition.. :cfingers::eek:
I have also been thinking about the fact that %GRR is a relative value related to the part variation - and I never really got my head around it to make logically sense, and has also been tempted to use specification instead.
Thinking about it:
-the higher part variation of the process, the more likely it is the Cpk will not be ok
-the higher part variation of the process, the more likely it is the %GRR is ok
I guess the last pin is why it is so important to have parts that represents the WHOLE process
So, I need to find a variation in between to satisfy both, either by:
-Less variation from Appraiser/Equipment (= lower %GRR score)
-Higher tolerences (= better Cpk-value)
I guess It would be a good idea to conduct a capability index of the measurement system prior its first use - like a Measurement System Capability Type-1 Study as described in VDA (Cg=1,33=10% of tolerance) to ensure EV is under control.
Any other input much appreciated as I am still trying to get my head around this..:read:
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
J AIAG MSA and Gage R&R - What does the Process Variation % R&R truly mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Gage R&R Criteria on page 78 MSA Reference Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
C Gage R&R/MSA for PPAP - Our product has no variance Statistical Analysis Tools, Techniques and SPC 9
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
2 MSA when neither Nested nor Crossed Gage R&R is Applicable Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Runout Gage R&R - MSA on Roundness Tester - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
bobdoering Dr. Wheeler is back with his thoughts on MSA and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Gage Run Chart Analysis - Page 105 MSA manual 3th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc MSA (Measurement Systems Analysis) and Gage R&R Spreadsheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
P MSA (Measurement Systems Analysis) Gage R&R with 10 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A MSA and Gage R&R for Measuring Microscope Capability, Accuracy and Stability - Processes, Machines, etc. 5
T Are MSA?s (Measurement System Analysis) Process or Gage Based? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
M Output of Nested MSA Gage R&R - Is this possible? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P AIAG SPC Manual (ver.1) Interpretations related to Gage R&R (GR&R) and MSA IATF 16949 - Automotive Quality Systems Standard 8
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q Internal Testing and Calibration Laboratories - MSA, Gage R&R and Control Plans IATF 16949 - Automotive Quality Systems Standard 2
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Significance of X chart in AIAG MSA sheet for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Z Determining how many measurement devices need gage R&R? MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
H MSA Excel .xls worksheet that includes GR&R (Gage R&R), Bias, Linearity, etc. Excel .xls Spreadsheet Templates and Tools 15
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D When is MSA (Measurement System Analysis) appropriate on a custom built gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z MSA - Gage R&R Study Analysis - SAMPLE - Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
R MSA and Gage Tracking Software that complies with MSA 3rd Edition Quality Assurance and Compliance Software Tools and Solutions 6
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K MSA 3rd Attribute GR&R (Gage R&R), no operators - Air decay test systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA (Attribute Gage R&R) on our process monitoring points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
