Gage R&R nested on Minitab
#11
ptitevy said:
Hello... Indeed may if I were a native English speaker it would have been easier to understand each other... Anyway, I think we are on the right track
You're doing fine. You don't want to even think about what might happen if I had to do this in your language. The result might be an international incident:lmao: .
OK--the small strips are cut based on the belief that the amount of PE on the entire length can be accurately estimated by measuring the amount on a small portion of it? In other words, if the whole strip contains x grams of PE, and we cut a strip equivalent to 1/10 of the whole, then the assumption is that the amount of PE on the whole strip is equal to 10 times what's found on the cut sample? If this is the case, are you sure that the amount of PE hanging off is linear (uniform) across the big strip, or is that what you're trying to determine?
P
ptitevy
#12
Probably... Did I tell you that the factory is in Hungary? Hungarian is a terrible language... I am sure you have no idea how it sounds...
The aim of this measurement is to know the {average} grammage of the waste PE. Of course we would like to know if the PE is constent, but this is a sub issue, and it SHOULD be constent.
We are trying to determine the consistency of the cutting method.
Please fell free to ask more questions if I am still too vague...
#13
But you haven't answered my questions, so I'm not sure how I can help:
  1. If you want to know the average, why don't you just measure (weigh) the big, original strip. Why do you cut it into pieces?
  2. How do you isolate the amount of PE on the samples, if the samples also include paper?
  3. Why not just take 10 or twelve samples, have 3 operators weigh them and see how close the results are, without doing a lot of potentially unnecessary calculations?
P
ptitevy
#14
I don't know how I express my self but it seems that nobody understand me :(
Answers:
1/ to test reproducability and repeatability
2/ {paper + PE} sample is given to operator. Then the issue is about how acurate the operator will get ride off the paper !! So {only the PE} is weighted
3/ this is what was done. we don't how the operator can be constent while cutting the samples (when the paper is removed)
For me it seems that I can not be more clear...
Anyway I am still ready to answer to questions...
But WHO will tell me what to do and how to enter data in Minitab ?
M Experimental Design at Nested Gage R&R using Minitab 16 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Minitab 15 Gage R&R Study Nested understanding Using Minitab Software 1
J Gage R&R nested on Minitab Using Minitab Software 1
J Nested Gage RR Accounting for Process Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
optomist1 Nested Gage R & R One Operator One Sided Spec Using Minitab Software 5
2 MSA when neither Nested nor Crossed Gage R&R is Applicable Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
7 Gage R&R Study (Nested) - Feedback and Comments appreciated Quality Tools, Improvement and Analysis 1
C What is a Nested GR&R and Crossed GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Nested Gage R&R - Studies on Crimp Fastener Tools Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Output of Nested MSA Gage R&R - Is this possible? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Sample Size of GR&R (Gage R&R) on Nested Anova Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B When to use a Nested Gage R&R vs. a Crossed Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
