Gage R&R on a Manual CMM
Al Cohen
Manual CMM Gauge R and R
Quality people!!
Has anybody carried out an R and R study on a manual CMM? Typically using tolerances of +/- 0.20 mm (0.007"). Would be very interested to find out what other labs have found....
Cristi?nC
Hi Al!
What means manual MMC?
Some kind of "Measuring Machine by Coordinates"?
I read some R&R reports of such a machine, but as far as I remember all of them are not manual...
Regards.
Al Dyer
In a previous life we did have a manual CMM, and we put it through the regular R&R process. Our only concession was that we used 3 people that were trained on using the gage.
And all inspections took place in an environmentally controlled lab performing initial and final inspections only. No "on the floor" use.
Al...
B Gage R&R Criteria on page 78 MSA Reference Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
J Standard / Brown & Sharp Gage Tower model E8-5000 Manual General Measurement Device and Calibration Topics 1
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
E Gage Run Chart Analysis - Page 105 MSA manual 3th edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P AIAG SPC Manual (ver.1) Interpretations related to Gage R&R (GR&R) and MSA IATF 16949 - Automotive Quality Systems Standard 8
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
T TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J AIAG's MSA Manual 3rd Edition Attribute Gage Study - Calculating the UCI and LCI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Attribute Gage R&R Form - Long Version - AIAG's MSA Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 35
B AIAG's MSA Reference Manual, page 95, "Gage R&R Confidence Intervals" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F Meeting the AIAG's MSA Manual Gage R&R Bias, Linearity, Stability requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Gage R&R IATF 16949 - Automotive Quality Systems Standard 2
D HELP gage card not popping up Using GAGEpack Software 2
F How often should Gage R&R's be updated? Is there a recommended time-frame? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W What is dimensional layout of the gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Does a gage used for a visual verification need to be calibrated? Manufacturing and Related Processes 7
T Gage Numbering Using GAGEpack Software 6
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
PastorBee13 Attribute Gage R&R with no bad samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage type and data base maintainence Using GAGEpack Software 2
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Faro Arm, Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
PQ Systems Recipe for Success! 10 Ingredients for a Healthy Gage Management System Using GAGEpack Software 0
D Gage Repeatability for Faro Arm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
PQ Systems Best Practices In Gage Management Using GAGEpack Software 0
PQ Systems Gage R&R - 3 Part Series Using GAGEpack Software 0
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Repeatability Type 1 Gage and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
