Gage R&R on a special go/no-go attribute gage
K
KlausDK
I have an problem with makeing a MSA on a special go/no-go gage.
The gage is used test if camber of flat substrates are below a specified value.
Camber is defined as the thickness of the substrate + 0.2% of the length of the substrate. if the substrate is 6,4" long and thickness is 0.635, the gap for the camber gage is 0.33 mm + 0.635 mm = 0.995 mm.
The gage is two flat and parralle plates that can be moved so they will have specified gap between each other, the plate are placed at 45° so the substrates has to fall under their own weight through the gap of the two plates.
I have to perform a MSA on this gage, my first problem is when I look at the attribute test in the MSA from AIAG that they easily find a "true" reference, I am not able to find the "true" reference value. As it is only the gage that is able to measure the "total" thickness (thickness + camber). The gage is a go/no-go system, but I can make selection with 0.01 mm difference in gap distance.
I have found 14 substrate which I have selected to be in 3 groupes that pass at 0,850-0,855 0,855-0.860 and 0.860-0.865. The I have marked and tried each of this substrates 20 times and registred the number of passes with a gap setting of 0.860 I have one substrates that do not pass and 11 that pass between 2 and 19 times, and 3 that passes 20 times.
I don't know the "true" value of each and is not able to establish this value by other measureing methods.
I can change the gap, and I can run trials several times with different operators.
Are there any body that has a good suggestion how to proceed.
M Not all special characteristics are monitored and Gage MSAs - Two NC's IATF 16949 - Automotive Quality Systems Standard 9
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
