Gage R&R on automated test equipment - No reproducibility error?
6
6sigmadeewana
I am trying to do a gage r&r on a testing machine. There is no operator involvement. All the operator does is put the part in the machine and the machine goes through a series of tests to give results. the machine has 3 "cups" so that 3 bulbs can be tested at a time.
Would there would be no reproducibility error since operator is not involved ?
How do I do a gage r&r on this machine ?
K
Katydid
If it inspects parts, as required you need a GR&R regardless if operators are involved or not. If the operator can misload and get a false negative (or failure), then you will also find that they do contribute to the gages ability to repeat measurements. Do you have a way to record the results for each check? If you have multiple stages and multiple cavities, you will have to consider each one to decide if it needs its own study. You may end up with cavity one at station 1, then 2, and then 3, then cavity 2 at station 1, then 2, then 3, and so on.
Good luck evaluating your system!
Have a look at this thread GR&R on automatic equipment such as a CMM.
The three stations should be treated as operators as the differences between stations is REPRODUCIBILITY error. The differences within a single station is REPEATABILITY error.
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Attribute Gage R&R analysis - Automated test system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
Y Is NDC needed for gage used for ATE? Automated Test Equipment IC Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
C Gage R&R on In-Process Automated Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Multiple Variation Gage R&R for Automated Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Gage R&R for Automated Measurement Equipment Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
C Multiple Fixture Automated Vision System GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GR&R (Gage R&R) for Automated Electrical Testing Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D GR&R (Gage R&R) for Automated Wafer Probe Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S How to carry out Gage R&R for automatic machines? Automated Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
H Attribute Gage R&R for Repair Station Operators - AOI (Automated Optical Inspection) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Automated Testing Gage R&R (Repeatability and Reproducibility) Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Howard Atkins Gage R&R with Automated Gages - No Operator Bias? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
