Gage R&R - Percent of Tolerance or Percent of Variation?
sinan_guler
hello;
I have a small problem with MSA. I need your help. This is my problem. I have got measurement data. But the USL and LCL is very high so from minitab %R&R is %Study*Var %44 but %Tolerance is %13. Could you help me which of these do i have to select.?
i have selected 25 parts. So i need to know k3 for 25 parts. this is my measurement data. I need to know my %R&R value.
for product USL:1,600 and LSL (1,500)
thank you very much
N
NumberCruncher
Hi sinan
I would need to put your data into minitab, which I don't have. But just looking at the data, you should check the data input. There are two values which are outliers. They may be correct, but it would be a good idea to go back to the original written records to check what was written.
Here are the relevant columns (4 and 9). I have highlighted the suspect data
4_______19
1.505___1.515
1.514___1.519
1.517___1.519
1.517___1.518
1.514___1.504
1.514___1.519
NC
debyang
Hi,Sinan guler
Because there are some points out the R chart’s UCL per your data, it indicates that your MS was not stable (as NC posted ), you have to investigate what ‘s wrong and fix the problems before going to worry about the % is good or not.
Only when R chart is stable, the GRR results can be accountable . You may go further to compare the GRR TV with product tolerance, or any known process SD or product SD. If the GRR TV is quite small thus makes your GRR% terribly large( might due to poor sampling), in order not to waste any resource on not necessary improvement effort on the measurement system, replace the GRR TV with other SD is the most practical measure. The best substituting TV should be the smallest one of the product tolerance and the process SD or the product SD.
Once you chose other TV, do remember to recalculate the PV(=sqrt((new TV)^2-(study GRR )^2))and ndc, so you won’t have good GRR% but poor ndc such contradictory issue.
J Minitab vs. GagePak - percent GR&R (% Gage R&R) Using Minitab Software 6
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
