Gage R&R procedure for Bulk Chemicals
Tom Banks
Could anyone assist me with a Gage R&R Procedure for Bulk Chemicals? I have one but want to make sure I am not missing anything to ensure it is value added and sampled properly.
bobdoering
Stop X-bar/R Madness!!
Re: Gage R&R Procedure for Bulk Chemicals?
What devices are you utilizing for your bulk chemicals? pH meters, scales, volumetric devices, moisture detectors, IR, NMR...? It is the devices and the processes they are used to verify that will determine the gage R&R techniques that are appropriate.
Tom Banks
Thanks for the reply....The following devices are being used: scales, volumetric devices, moisture detectors. The data is already being tracked but has not been put into a software to conduct data analysis and report the findings.
Would you by chance have a procedure I could use for general set-up of a gage R&R program in this field?
No procedures, but here is a link to my blog entry on non-replicable R&R studies.
Some of your measurement devices appear to be replicable (e.g., scales, possibly volumetric devices) and may be evaluated using a standard crossed MSA.
Others appear to potentially be non-replicable (e.g., moisture detectors) and may need to be evaluated using a nested MSA. If that is the case, my blog entry should assist in how you may run the study.
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
D Procedure for use of a Digital Indicator and a Height Gage Document Control Systems, Procedures, Forms and Templates 6
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
D GRR (Gage R&R) procedure for Mitutoyo Digital Micrometer wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
D Gage Out of Tolerance Procedure Document Control Systems, Procedures, Forms and Templates 3
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
D Improvement Plan for Gage R&R > 20% - Seeking Procedure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Can anyone suggest a GRR procedure for a Multi step plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Gage R&R for Pressure Transducers - What GR&R procedure / formula (standard) is best? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Electronic Differential Level Gage R&R Procedure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Trying to develop a written procedure for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Gage R&R procedure for Torque Wrench Needed - ISO 6789 and ISO 5394 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
