Gage R&R Records - Should we keep data longer as 'suggested' by our TS Auditor?
K
kat.k.
Our records retention for gage R&R's are:
The long form data (for new gages) is entered and stored electronically in our gagepack software.
Short form hard copy (for gage R&R's on yearly calibration) is retain latest copy only in case of computer failure. Only the results are entered electronically as part of the calibration.
The TS auditor asked our internal auditor why we don't keep them longer. He said the history may be helpful. I think the electronic data and results are sufficient. Should the hard copies be kept longer?
If the auditor makes suggestions, should we take these suggestions into consideration and make corrections?
Kat
Duke Okes
Re: gage R&R records
In both cases it's your organization's decision ... whether to keep them longer, and whether to go along with the auditor.
tuas11
Kat
I agree with Duke. You do not have to take up every suggestions that the auditors make. Weigh it against your company practises and see whether the suggestions will value add to your current processes.
In the case of keeping hard copies, I do keep both electronic and hard copies for my company GR&R records but that is also because I do not have that many gauges to start with. :D
Re: Gage R&R Records - should we keep it longer as 'suggested' by our TS Auditor?
If your electronic results contain all of the data that is in the hardcopy, you can always recreate the analysis on demand. ISO clearly states that electronic and hardcopy results are equivalent.
Do what makes sense to your organization. You are on solid ground if you choose to refuse the suggestion.
K
kat.k.
This is what I was thinking too. I like to get second opinions. Thanks for your help.
Kat
K
kat.k.
Thank you for your input.
Katrina
K
kat.k.
This has helped alot. Sometimes I know what I need to do but when the auditor suggests it, I like to have second opinions.
Thank you,
Kat
Did the auditor say why he thought it might be helpful? If, for example, an auditee has trouble accessing the electronically-stored data but is able to readily access a paper copy, I might be able to see the merits of the suggestion. As others have already pointed out, though, it's your call.
You should certainly take them into consideration, but you should only make corrections if the suggested corrections make sense for your company.
C Calibration/verification records - New gage certificate as calibration evidence General Measurement Device and Calibration Topics 4
L Minimum gage verification record - Evidence records of 'verified prior to use' Records and Data - Quality, Legal and Other Evidence 11
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
