Gage R&R (Repeatability and Reproducibility) for Dummies
N
nancichan
#11
Thanks everyone for the help! Caster, your notes sound like they would give me exactly the information I am searching for. Please can you get them to me somehow (email/scans)?
Many Thanks
x
Bpoole
#12
No known value
Can anyone give me an example of how to do a MSA study on a measurement tool with no know value. We use pyrometers to record the temperature of aluminum. We cannot control the temperature and therefore have no value to measure our temperature against. The TS standard states that we shall conduct analyse on each type of measurements referenced in the control plan. Any ideas?? :
#13
Why do you measure and record values you can't control, and don't care about? In other words, why is it in the control plan if you're not controlling it? What does your control plan entry say to do?
deltawillow
#14
I am sorry Ron but this file contains the 2nd edition constants that have been changed.
This file has the correct constants as well as other useful forms.
There are also other forms in the attachments but please check the constants
e.g K1 now = 0.8862 for 2 in the past 4.56
can you tell me where I can find the new d constants in the appropriately updated table - all my old R&R literature uses the previous edition's. ALso, what is the rationale for such a large change in the constants? prety radical change for statistical constants ( that I thought were as unchangeable as gravity or acceleration)
Coury Ferguson
Moderator here to help
#15
This thread is 3 years old, but maybe someone might be able to help.
#16
D2 for 2 Trials = 1.128, for 3 Trials = 1.693
D3 for 2 Trials = 0.853, for 3 Trials = .0888
D4 for 2 Trials = 3.27, for 3 Trials = 2.58
The 3rd edition made two notable changes:
  1. The first was to change from 5.15s (standard deviations) (99%) to 6s (99.73%)
  2. The second was to simplify the formula by omitting the multiply by 6 and divide by 6s to simply divide by s.
V
Voyteck79
#17
special procesess (painting, plasma coatings, brazing)
Few questions:
1. Can i use 10 simulated samples (simulation parts, scrap parts) instead running parts?
2. what is the procedure if i have tolerance min or max?
3. what measure must be write if: tolerance for dia is .755-.775, act dia is .7555-.7745 (his i sexample)? "big dispertion"
these are imprtant question forme to start doing this :truce:
regards!!!
#18
What will the gage be used for, inspection or process control? The answers to your questions depend on the answer.
#20
Since this gage is only used for inspection, you should use the P/T Ratio (% Tolerance) metric for assessing acceptability of the gage. This compares the gage error to tolerance. Process variation is not part of the calculation, so the dimensions of the parts are not terribly important unless the might affect how the operator may inspect them. It is good practice to select parts the use the entire range of the tolerance, but this is not mandatory.
1) As long as operators will measurethe simulated parts the same way they would measure an actual part, yes. Be careful that this is a correct asumption.
2) Do you mean a unilateral (1-sided) tolerance? You may want to use the PME (Probable Measurement Error) propsed by Donald Wheeler. The P/T Ratio has not been adapted to unilateral tolerances.
3) This sounds like Guard Banding. That is a business choice. Most do not unless the dimension is critical.
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Weight Scale Gage R&R (Gage Repeatability and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U Gauge repeatability and reproducibility (Gage R&R) worksheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Gage R&R (Reproducibility and Repeatability) using Minitab 14 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
U Gage R&R (Reproducibility and Repeatability) Understanding for the Layperson Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Gage repeatability and reproducibility - GRP% Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R How to Determine CMM Gage R&R - Accuracy, Repeatability, Reproducibility? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Gage R&R - Repeatability and Reproducibility of a newly bought CMM machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Automated Testing Gage R&R (Repeatability and Reproducibility) Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Courier Gage R&R (Reproducibility and Repeatability) - Automotive Requirements Basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R (Repeatability and Reproducibility) Study with one appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Determining Repeatability without Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
D Gage R&R Repeatability - How do I know my gauge is in specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Operator Capability - Gage R&R Poor Repeatability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Y Product Stability (Machine Capability) vs. Equipment Repeatability (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P Gage Repeatability (1x1x10) form - 1 part measured 10 times by 1 appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P Gage R&R (Repeatability and Reproducability): What are the calculation restrictions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J What is an acceptable Gage R&R (Repeatability and Reproducability) system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Marc Gage R&R (Repeatability and Reproducability) - Tolerance vs. Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
