Gage R&R (Repeatability and Reproducibility) for Dummies
Don_Amaru_Sarma
#42
By the way I have a question. Why is the standard set at 10-30% Not a more stringent measure such as 5%. Because in the plastics industry usually we practice an error level of <5%.
bobdoering
Stop X-bar/R Madness!!
#43
Clearly the smaller the better. For some applications the investment in gaging to reach a lower gage error level is not justified. BUT...10-30% is abjectly inadequate for SPC use. In fact the error should be less than 10% of the control limit range, NOT the specification! Otherwise, your true process distribution will be masked by gage and measurement error (although you won't know it and be tickled to see a normal distribution - typical of measurement error!)
AmQC01
#44
Extremely confused when is comes to tolerance range/ total variation. For one are they the same? Is the total variation something that my form should be filling in. I was told that this should be the total difference between the tolerence. Is this true? Please help.
Avelar
#46
Hello all,
I got some questions, I would appreciate if you can help me. What is the difference between the total variation and the tolerence in the form to obtain the R&R? Other question, when I made the study for one gage, the variaton between operaters was 0,01 at maximum and the values were all within specification, why I got 22% of RR?
Many Thanks for your support
#47
Welcome to the Cove :bigwave:
GR&R results may be expressed as percentage of:
  • Total variation--the actual process variation, if it's known;
  • Within-study variation--as its name suggests, only the variation seen in the GR&R measurements is used;
  • Tolerance--the amount of the total tolerance being consumed by measurement error.
Generally speaking, the first two are used when a measurement system is used for process control--doing SPC, for example--and the third is used when the system is used for inspection.
The question can't be answered definitively without seeing the data, but one cause might be that the 0.01 variation comprises a significant amount of the tolerance, or that part variation (within and/or between parts) was high. If you could post the actual data we can give a better answer.
Avelar
#48
Hello Jim,
Many thanks for your support. I am new in this forum, I will try to introduce an exemple with the values, specification and the R&R result.
#49
Hello Jim,
You're welcome. Our own MSA guru Miner has posted comprehensive MSA information in a series of blog posts here at the Cove. It's a treatment of the subject you're not likely to find anywhere else.
Avelar
#50
Good Morning,
Attached you can find an example of a RR study that I have performed. The specification is 11.2 and the tolerance is +0.2 to -0.45.
The study has 2 operatores, 3 trials. The difference between operators is very small but the result is too high. If it is possible can you explain this situation?
I thank you in advance.
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Weight Scale Gage R&R (Gage Repeatability and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U Gauge repeatability and reproducibility (Gage R&R) worksheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Gage R&R (Reproducibility and Repeatability) using Minitab 14 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
U Gage R&R (Reproducibility and Repeatability) Understanding for the Layperson Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Gage repeatability and reproducibility - GRP% Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R How to Determine CMM Gage R&R - Accuracy, Repeatability, Reproducibility? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Gage R&R - Repeatability and Reproducibility of a newly bought CMM machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Automated Testing Gage R&R (Repeatability and Reproducibility) Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Courier Gage R&R (Reproducibility and Repeatability) - Automotive Requirements Basics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R (Repeatability and Reproducibility) Study with one appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Determining Repeatability without Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
D Gage R&R Repeatability - How do I know my gauge is in specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Operator Capability - Gage R&R Poor Repeatability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Y Product Stability (Machine Capability) vs. Equipment Repeatability (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P Gage Repeatability (1x1x10) form - 1 part measured 10 times by 1 appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P Gage R&R (Repeatability and Reproducability): What are the calculation restrictions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J What is an acceptable Gage R&R (Repeatability and Reproducability) system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Marc Gage R&R (Repeatability and Reproducability) - Tolerance vs. Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
