Gage R&R (Reproducibility and Repeatability) - Automotive Requirements Basics
Courier
another day closer
Gage R&R
I Download the file PPAPALL.xls,(the newer file was called somthing like Partcertall.xls) It's Delphi,s Version 6.06 February 2000. I wanted to use the Gage R&R from it. But I had to update the newer K3 numbers from page 114 in the MSA 3rd Edition into it. Anyway the Question and problem I have is it uses two methods to choose from "Part to Part Variation" & Tolerance Method". The Part to Part method is in the MSA book but I was woundering where the Tolerance method came from i dont see it in the book, but it is in Delghi's file and they are used for Chrysler, Ford, & General Motors so it must be good to use right? and i think the upper limit allowed for GR&R is 10% not like the 30% used for Part to Part method. Is this Tolerance method good to use in a ISO/QS company for Gage R&R studys? and what are the allowable limits then to use? :frust:
Atul Khandekar
Courier said:
... Anyway the Question and problem I have is it uses two methods to choose from "Part to Part Variation" & Tolerance Method". The Part to Part method is in the MSA book but I was woundering where the Tolerance method came from i dont see it in the book, but it is in Delghi's file and they are used for Chrysler, Ford, & General Motors so it must be good to use right? and i think the upper limit allowed for GR&R is 10% not like the 30% used for Part to Part method. Is this Tolerance method good to use in a ISO/QS company for Gage R&R studys? and what are the allowable limits then to use? :frust:
Courier,
Welcome to the Cove Forums.
R&R is usually compared with the Total variation observed during R&R study (TV) and the acceptance criteria is 10-30%
You can also use:
1. Process variation as seen from your SPC studies and
2. Tolerance on the characteristic being measured
3rd edition MSA manual, on page 116 (Chapter III, Section B) states that "Either or both approaches can be taken depending on the use of measurement system and the desires of the customer"
In the book, "Concepts for R&R Studies", 2nd Ed, (ASQ Quality Press), Larry Barrentine describes these two ratios as Measurement Capability Indices (MCI-1, based on process variation and MCI-2, based on tolerance.)
As a general rule, comparing GRR with process variation is the preferred approach. The ratio of (GRR/ProcVar) indicates the 'distortion' in the process variation estimates due to measurement error. Since the process variation is the measure of what the process actually delivers on the shop floor, this ratio should be used if you use the measurement system to control the process. If GRR is high as compared to process variation, the measurement system does not have adequate 'discrimination power' to detect shifts and assignable causes in the process. This ratio can also be used in case of one-sided specifications.
The downside of using (GRR/PV) is that when the process is already very capable (say, Cp>1.67), it may indicate that the measurement system is inadequate when in fact improving the measurement system is not the topmost priority.
The other ratio (GRR/Tolerance) can be used when the measurement system is used for product acceptance decisions or inspection. This ratio indicates if you have sufficient 'space' to center the process within the specifications. If this ratio is high, the measurement system may classify good parts as bad ( and vice versa), esp. when operating near the limits of tolerance zone. Customer may accept a higher %of tolerance if the process Cpk is high. The problem with this approach is that specifications (in many cases) may be set arbitrarily.
Larry Barrentine prescribes acceptance criteria as under: (for both, MCI-1 as well as MCI-2):
<=20% :Good
>20 - <=30% :Marginal
>30% :Unacceptable
Hope this helps.
- Atul.
PS: Also see the graphs for impact of GRR on actual and observed Cp - MSA manual, Appendix B
Atul Khandekar
From the manual:
Some addition to my above post:
From Page 73 (Chapter II, Section C): MSA Manual
For Product Control situations where the measurement result and decision criteria determine, "conformance or nonconformance to the feature specification", (i.e. 100% inspection or sampling), samples (or standards) must be selected, but need not cover the entire process range. The assessment of the measurement system is based on the feature tolerance (i.i. %GRR to TOLERANCE)
For Process Control situations where the measurement result and decision criteria determine, "process stability, direction and compliance with the natural process variation", (i.e. SPC, process monitoring, capability and process improvement), the availability of samples over the entire operating range becomes very important. An independent estimate of process variation (process capability study) is recommended when assessing the adequacy of the measurement system for process control (i.e. %GRR to process variation)
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Weight Scale Gage R&R (Gage Repeatability and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U Gauge repeatability and reproducibility (Gage R&R) worksheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Gage R&R (Reproducibility and Repeatability) using Minitab 14 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
U Gage R&R (Reproducibility and Repeatability) Understanding for the Layperson Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Gage repeatability and reproducibility - GRP% Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
R How to Determine CMM Gage R&R - Accuracy, Repeatability, Reproducibility? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Gage R&R - Repeatability and Reproducibility of a newly bought CMM machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D Gage R&R (Repeatability and Reproducibility) for Dummies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 67
A Automated Testing Gage R&R (Repeatability and Reproducibility) Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Gage R&R (Repeatability and Reproducibility) Study with one appraiser Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
P Gage R (no reproducibility) - Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Gage R&R not passing for Check Valves Crack Pressure - No Reproducibility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N Repeatabilty + Reproducibility (Gage R&R) Study - Inter-Laboratory Study (ILS) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Operator Training - Variation and reproducibility in testing and Gage R&R Training - Internal, External, Online and Distance Learning 10
6 Gage R&R on automated test equipment - No reproducibility error? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Is ANOVA Gage R&R the best method? Reproducibility issues (no inspector effect)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Gage R&R (Ranges Method) - Reproducibility standard deviation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Go - No Go (Attribute) Gage R&R (Repeatibility and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 52
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
