Gage R&R Results - ?Number of Distinct Categories = 1?
CMfgT
Gage R&R Results - “Number of Distinct Categories = 1”
Can someone help me explain my Gage R&R results? I know most of my problem is I have “Number of Distinct Categories = 1”. I guess I don’t understand why I keep getting that. I attached my data and a few graphs from Minitab.
Some background info. The part feature being measure is a 1.181” OD with a tolerance of 0.001, so my UCL=1.181” and my LCL is 1.179”. I measured with the 10/1 rule so I included the 4th decimal place (tenths or .0001). Is this my problem?
I also run two different software programs and get two different results? What does everyone else use?
Any help would be appreciated.
bobdoering
Stop X-bar/R Madness!!
Re: Gage RR Results
Two questions:
1) What gage are you using and 2) Are you measuring the exact same spot on the part each and every time?
achorste
Re: Gage R&R Results - “Number of Distinct Categories = 1”
Well, I don't think it's the software you are running that is giving you your failed gauge R&R, or your gauge resolution (which, at a tenth of the tolerance, should be adequate).
If you look at all the results from each part in isolation, the ranges of results you are seeing is up to 0.0018", which is nearly the size of the tolerance itself.
Can you give us any more info on the measurement system itself?
CMfgT
Re: Gage RR Results
Look at your RESULT by part data. The error of the measurement is taking up the whole spec - even if the gage reads to .0001.
Two questions: 1) What gage are you using? 2) Are you measuring the exact same spot on the part each and every time?
How is the error taking up the whole spec. The tolerance is .001", and the normal range is .0003 or .0004.
1)Using a 1-2" OD mic. Appraisers are using the same mic and same gage block to zero the mic to thier feel. The mic is a friction mic. I think this is where the human error is coming in. Appraiser A from trial 1 to trial 2 was consistantly .0002" off. The operators zeroed the mic each time.
Thanks,
achorste
Re: Gage RR Results
If you look at the top right chart on the minitab output it shows the spread of results by part, this spread covers up to 0.0018, in 3 cases 0.0015. The operators tend to average out ok, but that is masking the real problem that the amount of variation in the results obtained is too great to give you a reliable measurement system.
CMfgT
Re: Gage RR Results
I am confused?? I posted some data to support my question. I see where Minitab says I have a range of .0018, but when I compare my data in excel, the biggest range an operato has is .0006"
What am i Missing here?
CMfgT
Re: Gage RR Results
I found an error in my excel formula converting the results to part numbers. I had the wrong part numbers assigned to results. Let me fix and repost. Sorry.
I'm confused. You're referring to UCL and LCL, (upper and lower control limits) but I think you mean USL and LSL (upper and lower specification limits). If this is the case, what do you mean by "a tolerance of .001"? The fact that you identify the "LCL" as 1.179 (.002 less than 1.181) indicates that the total tolerance is something other than .001. Can you clarify?
CMfgT
I attached the new data with info. Alot better. First off I am sorry, I had a typo, so my part number results were mixed up.
Clarify, I ment to say my +/- tolerance is .001, so I have .002 overall.
Now, is my total gage R&R 28%?
achorste
A lot better indeed :D
Your total Gauge R&R %Tol is 46.79, the % Study variation is 28%.
From a quick skim of the data, my opinion would be that you still have an issue with operator repeatability.
We had a similar issue with a bore on one of our components with a 0.001" total tolerance - we first off tried a bore mic, but with all the variation (including human factors) we just couldn't get a repeatable measurement system.
In the end we switched to a combination of sample CMM and 100% Go / NoGo gauging. (Sample on CMM for SPC purposes - but be warned - the CMM is only as good as the fixturing, program and set up, and even then it will only give you an average - hence why we stuck with Go / NoGo gauging)
C Gage R&R study definition - Results for GRR is .0005 - What does this number tell me? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to interpret Grindometer Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Strange Gage R&R results for a Caliper (Tolerance Method) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Y Poor Gage R&R Results - High R&R result and poor ndc value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Gage R&R Minitab 'crossed' confusing results Using Minitab Software 3
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T What does the Gage R&R results tell about my Accept/Reject Decisions? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Gage Bias and Linearity - How to interpret the Minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Interpreting Gage R&R Results - 3 operators, 3 iterations and 10 parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
F Gage R&R - How to interpret results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Spreadsheet Results - Confused as to what the results mean Inspection, Prints (Drawings), Testing, Sampling and Related Topics 28
S Using the results from GR&R (Gage R&R) Analysis - One sided dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
G Help in understanding my Gage R&R results on a pH meter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Could someone tell me what are the results of a Gage R&R & how to interpret it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C 1st Gage R&R Results help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 48
M Poor Gage R&R results (30%RR to 80%RR) - What Next? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Interpreting Minitab Gage R&R study results - Relative Crease Strength (RCS) Using Minitab Software 3
P Can the GR&R (Gage R&R) results for one P/N be used for mulitple P/Ns? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Gage R & R - How to enter appraiser results into an Excel .xls spread sheet Excel .xls Spreadsheet Templates and Tools 12
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
Howard Atkins Values and results to check Validation of Gauge (Gage) R&R program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
K Gage R&R - How do I interpret the %PV & %TV results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S What are Acceptable Limits for Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Geoff Cotton Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories Using Minitab Software 4
J Gage R&R - Consistent Readings, Inconsistent Results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Acceptable Gage R&R Output Results - EV, AV, R&R, PV, and TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
