Gage R&R Results - ?Number of Distinct Categories = 1?
bobdoering
Stop X-bar/R Madness!!
#21
Re: Gage R&R Results - “Number of Distinct Categories = 1”
Yes, as stated above, I used a friction mic which minimizes this error. I believe this error is a main cause when setting or zeroing the mic. We ordered a snap gage, so hopefully another gage r r will yield better results and will justify spending the money on snap gages.
Good idea. Even a friction mic can create error by impact. If an operator spins down at a different speed each time, it can still create error. Standard micrometers are generally just bad news. I have seen huge GR&R improvements with snap micrometers.
#22
Can you clarify what you mean by "Your total Gauge R&R %Tol is 46.79, the % Study variation is 28%." What is the difference? I know my gage rr value must be below 30%. If a customer called and asked for my gage r and r value, what value are they looking for? what is the difference.
thanks,
  • %Tol = 46.79% means that gage variation consumes 46.79% of your tolerance. Use this if your gage is used only for inspection to tolerance.
  • % Study Variation = 28% means that the gage variation consumes 28% of the variation seen in your study which theoretically includes your process variation. Use this if you gage is used only for SPC or statistical studies.
  • Use both if your gage is used for both inspection and SPC.
BTW, these questions are related to another thread that you started. They should be part of the same thread, not separate.
ROOPA KODE
#23
Hi all
Last week we had a survilence audit where the auditor has gone thru one of the R&R studes done with optical comparator.The ndc obtained in this case is 425.Onseeing that he said that its impossible to get an higher ndc like that and said that this report is definetly a fake one.But actually its a valid r&r carried on.Can anny one suggest how to manually interpret the ndc and what could be the maximum limit for ndc
Barbara B
#24
Welcome to the Cove :bigwave:
A huge ndc is rare, but possible. If you have a %SV (study variation) of 0.11%, you'll get ndc=425. %SV depends on the ration between VarComp(gage) and VarComp(total):
%SV/100 = VarComp(gage)/VarComp(total)
If the variation of the gage is tiny compared to the total variance, you'll get a high ndc (see Minitab knowledgebase ID 2393: Relationship between the number of distinct categories and % Study Variation for details).
This will happen if the selected parts are really different and cover a broad interval comparing to a gage with a minimal measurement uncertainty and no operator effects.
#25
I have seen large NDC values in that range before and they can be valid...
the best help we can give you is if you post your data and explain the characteristic and how it is measured...
C Gage R&R study definition - Results for GRR is .0005 - What does this number tell me? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to interpret Grindometer Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Strange Gage R&R results for a Caliper (Tolerance Method) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Y Poor Gage R&R Results - High R&R result and poor ndc value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Gage R&R Minitab 'crossed' confusing results Using Minitab Software 3
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T What does the Gage R&R results tell about my Accept/Reject Decisions? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Gage Bias and Linearity - How to interpret the Minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Interpreting Gage R&R Results - 3 operators, 3 iterations and 10 parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
F Gage R&R - How to interpret results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Spreadsheet Results - Confused as to what the results mean Inspection, Prints (Drawings), Testing, Sampling and Related Topics 28
S Using the results from GR&R (Gage R&R) Analysis - One sided dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
G Help in understanding my Gage R&R results on a pH meter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Could someone tell me what are the results of a Gage R&R & how to interpret it? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C 1st Gage R&R Results help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 48
M Poor Gage R&R results (30%RR to 80%RR) - What Next? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Interpreting Minitab Gage R&R study results - Relative Crease Strength (RCS) Using Minitab Software 3
P Can the GR&R (Gage R&R) results for one P/N be used for mulitple P/Ns? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Gage R & R - How to enter appraiser results into an Excel .xls spread sheet Excel .xls Spreadsheet Templates and Tools 12
J Gage Block Calibration Results and Taking Uncertainty into Account General Measurement Device and Calibration Topics 3
Howard Atkins Values and results to check Validation of Gauge (Gage) R&R program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
K Gage R&R - How do I interpret the %PV & %TV results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S What are Acceptable Limits for Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Geoff Cotton Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories Using Minitab Software 4
J Gage R&R - Consistent Readings, Inconsistent Results? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Acceptable Gage R&R Output Results - EV, AV, R&R, PV, and TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
